Results 1 to 9 of 9
    Apr 2015
    Chain Length in Links?
    52/36 105 crankset, new Ultegra chain and 11-28 cassette. Kind of hate always having to guess-timate chain length - anyone have a similar setup? how many links to trim off?
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    How long is a piece of string?
    You can't go by someone else's chain length as their chainstays are undoubtedly different length than yours. And are they using a short or medium cage derailleur?
    Never guesstimate. Use a proper sizing method.
    You can't go wrong using the small small installation method.
    https://www.artscyclery.com/learning...roadchain.html
    Or use the method instructed by Shimano
    'brifter' is a lame word.
    Quote Originally Posted by jmcg333 View Post
    You haven't provided anywhere near enough info to do this, and it's the worst possible way to size a chain. As tlg posted if everything is in spec the small/small method is pretty easy and fool proof. Never guess at chain length.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2006
    The second method worked perfectly for me, and there's no guesswork. Wrap the chain around the biggest cog and biggest chain ring, bypassing the derailleur. Add two links (one inch).
    See the Park Tool link below, on matching up inner and outer plates on the chain ends:
    More details here, with photos: Park Tool guide: Chain Length Sizing
    tlg
    tlg is online now
    May 2011
    Quote Originally Posted by rm -rf View Post
    There's one caveat to this method. You can never go to a larger cassette or chaining.
    a real member's member
    Jul 2016
    Kind of hate always having to guess-timate chain length.
    was there already a chain on the bike? use that. it may not be right, but it's often an effective starting point.
    Apr 2015
    Thanks the info-graphic helped I was having trouble until I just measured with the quicklinks on - for some reason I can't wrap my mind around this chain stuff.
    And with limited fingers and toes counting links isn't so good either. Not for me anyway.
    But yeah, like someone else said use the previous one to measure against of course assuming it's okay and you're using the same cassette and rings.
    Nov 2014
    Note that Shimano actually has an older Campy-style sizing method for cassettes 27t and lower. Kind of the way we used to size chains for straight blocks back in the day.
    See, http://si.shimano.com/pdfs/dm/DM-CN0001-05-ENG.pdf
  1. Links, links and more links
    By tihsepa in forum The Lounge
    Last Post: 11-28-2013, 05:20 PM
  2. Chain length/links calculator
    By AJL in forum Components, Wrenching
    Last Post: 11-10-2009, 10:25 AM
  3. Connex chain links not meshing correctly with DA chain
    By dasho in forum General Cycling Discussion
    Last Post: 03-31-2007, 05:34 AM
  4. 96 Links of chain on by bike, 96 links of chain..
    By hrv in forum Fixed/Single Speed
    Last Post: 03-22-2004, 08:44 AM
  5. Remove links from SRAM hollow pin chain with a normal tool?
    By OxfordUKRider in forum Components, Wrenching
    Last Post: 02-26-2004, 02:38 PM
