Results 1 to 25 of 35
    Aug 2016
    Chain rubbing on big chain ring
    Will buying spacers get rid of this problem? I am using a GXP 53/39 with an 11-25 (Sram red). The rubbing occurs on the two top gears (11T and 12T. When set on the smallest chainring (39) the chain rubs slightly on the biggest chain ring (53)
    Sent from my SM-G935T using Tapatalk
    Oct 2014
    how in the world can we know what's wrong with that little bit of information?
    I mean you didn't even tell us what brand, model, etc...
    Is it only in one gear? or all the time?
    I've personally never heard of having to use spacers to keep my chain from rubbing on anything...
    Aug 2016
    You're right Sorry for the lack of info given. I am using the Sram red groupset and the chain rubs on the top two gears. (11T and 12T). After passing those gears everything seems to be running perfect
    Aug 2013
    Deletion - Edit flowing from OP edit.
    Aug 2016
    Quote Originally Posted by crit_boy View Post
    At the risk of being told I don't know what I am talking about. . .
    Sounds like your front derailleur is not adjusted properly. Did you adjust it after you replaced your old 36/52 with your new 39/53?
    After setting the proper height and angle, you have to set the stops. Then set the cable tension. If you have rubbing on the outside of the front mech while in the 11 and 12 in the back, my guess is the outer stop is too tight or the cable tension is insufficient. IOW, the front derailleur is not moved away from the frame enough.
    Do some reading or watch youtube videos about setting up a front derailleur. If that fails, take the bike and $ to the LBS and have them adjust it.
    Yeah I adjusted it after switching to the 53/39. I left 1mm then 2mm to see if anything would change but nothing I am pretty sure everything else is in perfect order. I'll take pics of the front derailleur in the morning and if all else fails then I'll take it to my Lbs :/
    Oct 2014
    So the chain is rubbing on the outer edge of the front derailleur when the chain is on the big chainring in front, and the smallest cogs in the back?
    Check your high limit screw, derailleur height, check if it's aligned with the face of the chainring (in accordance with SRAM documentation), and lastly (and most obviously) cable tension.
    You don't mention what crankset you are using, or what type of bottom bracket, but unless you are using something very non-standard, or there is something amiss with your chain line, there is no reason you should need spacers to prevent your chain from rubbing.
    Jan 2010
    After careful reading of the thread I am unsure what the problem is.
    Unless we are talking extreme cross-chaining, how can the chain rub on the big ring?
    OP, if this happens in the small chainring - small cogs combo, then it's not uncommon, and the cure is simple - don't do it.
    There's sometimes a buggy.
    One.
    Quote Originally Posted by bikerjulio View Post
    Same here. And despite not knowing the problem I can't imagine what spacers could do to correct whatever it may be. Or where you intend to put said spacers.
    Does sound like you just need to set up the der properly.
    Feb 2002
    The OP edited his post to say small ring, smallest two cogs in the back.
    1. Common problem, though not universal with every setup
    2. Using BB spacers would probably mess up the chain line, though if the chain line is off it might help.
    3. Obviously derailleur adjustments have nothing to do with this.
    4. If the chain line is right and the chain rubs, then Julio's advice is perfect: don't ride in these gears. Running at this end of the cassette is a formula for more rapid chain and cassette wear and a slight increase in drivetrain friction.
    'brifter' is a lame word.
    This has nothing to do w/ the front derailleur. The OP says his chain is hitting the big ring when he's on the small ring and the 2 smallest cogs. I haven't looked lately but it was previously stated in both SRAM and Shimano service instructions that you might not be able to use the 3 smallest cogs when in the small ring because of interference w/ the big ring. It's normally more of a problem w/ compact cranks because of the great difference in size between small and large rings. Chain stay length also comes into play.
    The OP can adjust his derailleur over and over but it won't make any difference. What he can do to stop this from happening is obvious. Stop cross chaining small/small.
    I work for some bike racers
    and a bunch of skateboards
    Oct 2014
    I wondered about this. His description of the problem is so poor, I really wasn't sure.
    I interpreted his thread topic to mean his chain rubs when it's on the big ring, not rubs on the big ring (just because it's a far more likely scenario). Of course, I could be completely wrong.
    Hopefully he'll come along and clarify for us...
    Aug 2016
    Cx wrench got the whole idea. I edited the post with more onfo.
    Sram red groupset
    GXP
    53-39 w 11-25
    Rubbing occurs on 11T and 12t and it happens when I switch to the 39. The chain rubs on the 53. I adjusted the cable tension and the both derailleurs but nothing has changed
    Jan 2010
    Quote Originally Posted by Rarely.Seen View Post
    Sram red groupset
    GXP
    53-39 w 11-25
    8 hours ago I told you the solution.
    Then Kerry agreed.
    Then CX agreed.
    One.
    Jun 2008
    Take that as a signal that it's time to shift into your big ring and into the middle of your cassette
    a real member's member
    Jul 2016
    Quote Originally Posted by sheldon brown
    Generally, the large outer chainring shouldn't be used with the largest rear sprocket, because of the sharp angle [the chain] creates. Similarly, the small inner chainring shouldn't be used with any of the smaller rear sprockets.
    The small-small combinations create extra problems besides the bad angle. The smaller the front chainring, the greater the pull on the chain; the smaller rear sprockets only engage a very few teeth with a very few chain rollers at any one time, so stresses are concentrated. If you make a habit of abusing the small chainring of a triple crank by using it with the smaller rear sprockets, you will drastically increase the wear rate of both chain and sprockets.
    from Gear Theory for Bicyclists
    Mar 2013
    Then Kerry agreed.
    Then CX agreed.
    I agree as well
    Jan 2010
    Quote Originally Posted by Roland44 View Post
    I agree as well
    Then Swift agreed
    Then Black agreed
    Then Rolly agreed
    If only there was this much agreement on other topics
    One.
    I fully agree w/ my post.
    Apr 2011
    That's funny, cx
    Reputation: Lombard's Avatar
    May 2014
    Then Swift agreed
    Then Black agreed
    Then Rolly agreed
    Agree here too. There is no way to prevent this rubbing in the small/small combo. Believe me, I tried by adjusting the FD cable and ended up with chain drop issues. So you have only two choices. You can either not use the small/small combo OR you can just live with the noise and the eventual grooving of your FD. Period.
    -- Warren Buffett
    is riding in MOPP4
    Reputation: Tachycardic's Avatar
    Mar 2013
    Go to a 1x setup. I guarantee that you won't have problems with chains rubbing on chain rings
    Wake me up when it's alarm green.
    Jan 2010
    This is the most agreeable thread ever in the history of threads. It's a Festivus miracle!
    One.
    Oct 2013
    Just take the big ring off, then it will not rub... ever.
    I'm not aggreable.
    BANNED
    May 2014
    Patient: It hurts when I do that. Doctor: Then don't do that.
    -- Warren Buffett
    Jan 2010
    The late great Tommy Cooper (you have to be English probably to know of him), had a variation:
    "I went to the Doctor, and I said "Doctor I've broken my arm in several places". Doctor says "well don't go to those places"."
    One.
  1. Replies: 17
    Last Post: 07-20-2015, 09:15 AM
  2. Chain rubbing middle ring
    By FreeRojo in forum Components, Wrenching
    Last Post: 05-19-2014, 05:12 PM
  3. Cross-chain noise - chain rubbing chainring
    By OldZaskar in forum Components, Wrenching
    Last Post: 04-15-2014, 07:51 AM
  4. Replies: 12
    Last Post: 03-02-2010, 06:12 PM
  5. Front Derailer Rubbing when on Small Front Chain Ring
    By FINEMNT in forum Components, Wrenching
    Last Post: 01-22-2010, 01:26 PM
