Results 1 to 4 of 4
    Jul 2007
    Changing Brake Pads?
    Looking at changing to Carbon wheels and need to change brake pads to some carbon compatable pads.
    Never have changed brake pads before. Can you just change the pads from on the same holder?
    I have shimano Ultegra brakes (less than one year old).
    Could someone who has experience doing this explain how to change the pads inside existing holders?
    Reputation: JCavilia's Avatar
    Sep 2005
    With Shimano it's really easy, because they have a little set screw that holds the pad in. When you loosen that screw the pad slides out easily. If you just look at them it's pretty obvious how to do it.
    Jul 2007
    Thank you for this kind responce
    Quote Originally Posted by JCavilia View Post
    Sep 2005
    You're welcome.
