Results 1 to 21 of 21
    Jun 2011
    Choosing proper crank length
    If I'm going to order a 105 groupset I need to know which crank length to get: 170mm, 172.5mm or 175mm.
    Is this purely a question of my size, bike fit, and overall geometry? Or does it really matter that much?
    I never gave it a second thought on my mountain bikes, just bought the standard 175.
    Thanks.
    Oct 2008
    Whats your inseam and how tall are you?
    Reputation: Ventruck's Avatar
    Mar 2009
    It's a feel thing. As studies can't make a firm, collective conclusion on matching cranks to leg length. If I were you, I'd stick with 175mm since you've been with it previously.
    I personally made a move from 175mm (on a hybrid) to 172.5mm on the replacement road bike. Didn't realize the difference. But the move to 170mm went from tolerable to crap over the span of months. Some riders use different lengths between road and TT bikes.
    Jun 2011
    I'm 5'11" and my inseam is 34 I believe...
    I'm interesting.
    Reputation: superjesus's Avatar
    Jul 2010
    Lennard Zinn on crank length (Link via VeloNews)
    Lennard Zinn crank length follow up (Link via VeloNews)
    "This thread gives me hope that the human race will render itself extinct in my lifetime...." PlatyPius
    "You're not a real cyclist unless you spend money needlessly....." ZoSoSwiM
    "Power is power and it has to be paid for." Alex_Simmons/RST
    A wheelist
    Reputation: Mike T.'s Avatar
    It's a "feel" thing with broad generalizations. I'm 5' 8" but with longish (33") inseam. I use 165 for my track bike, 170 for two road bikes and my mtb and 172.5 for another road bike and they all feel good. 175 for my mtb just didn't seem right. I'd suggest 172.5 for you
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilder's with motivation, information and resources.
    Everything above, up to that blue line, is IMO IMO.
    Feb 2010
    After much agonizing between 172.5 and 175, I finally made the move to 175. Way more torque. Highly recommended.
    pmf
    pmf is offline
    I went from 172.5 to 175 because the cranks that I wanted were on sale, but only in 175. Frankly, I didn't feel any difference. Think about how long 2.5 mm is. It's roughly 0.1 inches. I'd bet cleats differ by more than that. Anyone who can tell you they feel a big difference probably is also enjoying that plush carbon seat post as well.
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by rubbersoul View Post
    "Way more torque" from 1.5% increase in crank length. It's like magic.
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by JCavilia View Post
    It's like magic.
    More like "sleeping through Physics 101."
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by pmf View Post
    This. Between morning and evening, your feet probably swell more than 2.5mm
    Adventure Seeker
    Reputation: Peanya's Avatar
    Jun 2008
    And yet, we change gears, which cancels out the effect.
    From what I've discovered, it has very little to do with leg length, but the flexibility of the person, and a personal preference. Larger cranks make you work more, because you're flexing over a bigger circumfrence.
    As many will tell you, you won't be able to tell the difference between 170 & 175 on a test ride. Over a long distance, shorter cranks help my legs feel fresher though.
    I have a single track mind
    Feb 2002
    Cadence
    Quote Originally Posted by Patterson View Post
    As others have noted, there is no reliable way to predict what crank length will work "best" for you, as if it would even be possible to define "best." Shorter cranks make it slightly easier to spin. That's about it.
    And whatever you do, ignore the "Way more torque. Highly recommended." comment from rubbersoul. It is pure nonsense.
    Apr 2007
    You'll be happy with a 172.5 or 175. If you can, find a bike with 172.5, take it for a spin right after you've ridden your mtb. I can tell a difference between 170, 172.5 & 175 arms within a couple pedal strokes. As other folk have said, you can spin a shorter crank a little easier, and you'll get a bit more leverage on a longer set. I'm sure a 170 would not be your optimal choice.
    A wheelist
    Shorter cranks make it slightly easier to spin. That's about it. (longer cranks give) "Way more torque. It is pure nonsense.
    As a regular user of 165 to 172.5 cranks (and years of mtb 175 cranks in the past) I know that it's easier to spin shorter cranks. And as I'd rather pedal than push, I choose shorter cranks than longer.
    Jan 2011
    Isn't it (to a degree) independent of your leg length? I know some tall riders who use relatively short cranks....
    LC
    LC is offline
    I would also suggest 172.5 for you
    Reputation: ProdigalCyclist's Avatar
    May 2011
    The one negative experience I've had with crank length is just before a racing season (when I was younger , which was a long time ago) I changed from a 170mm to a 175mm and that was the only time I had any significant problems with my knees. Since then I use 172.5mm and have never had any other problems.
    Now this is not to say that it was just because they were 175mm and 175mm cranks will give you problems... the moral of this story is don't make a big jump in size and then pound big gears right away... I think it was because I jumped all the way from 170 to 175 and then over did it too soon.
    [SIGPIC][/SIGPIC]
    If you get a chance... follow a riders return to the bike after a 15+ year "offseason' at http://theprodigalcyclistca.blogspot.com/
    Jun 2011
    OK thanks everybody for your advice. My trusty local bike shop owner told me to go for 175 based on my height and what I'm used to.
    Thanks.
    Oct 2008
    I think thats the "you can ride anything" height.. If you were 6'2 id tell you to go to a 175. If you were 5'2, id say 170, pretty solidly for both.
    Ive been riding my 170 crank'd roadbike all year now.. after hopping on my mtb with 175mm cranks, It felt very off. I used to ride 90% mtb and 10% road using the same two bikes and never really noticed the difference. Im 5'8. Im sure Id get used to my 175 cranks if I rode them more, but the 170 juuuuust a bit feels better.
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    One should consider that your knees lift TWICE the distance of the difference in crank length at the top of the stroke, so about 1cm more for 175mm vs 170. If you have knee problems this could be significant. I have torn ligaments in both knees and can only ride 170mm or shorter cranks.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't %^&* like that since I was an altar boy" Hank Moody
  1. Proper chain length?
    By apoint in forum Components, Wrenching
    Last Post: 02-10-2011, 10:48 AM
  2. Stem length - proper fit
    By Jack1576 in forum Components, Wrenching
    Last Post: 01-31-2006, 01:36 PM
  3. Proper Chain Length
    By gorocketgo in forum Components, Wrenching
    Last Post: 01-27-2006, 08:03 AM
  4. Proper/Optimal Crank Length?
    By sfeastbayroadandmtn in forum Components, Wrenching
    Last Post: 05-05-2005, 09:40 AM
  5. Proper BB length????
    By TNSquared in forum Components, Wrenching
    Last Post: 03-16-2004, 12:13 PM
