Results 1 to 5 of 5
    Oct 2004
    Chris King Aheadset and Carbon Steerer Problem
    I have never encountered this before, and did a quick search of the forums and did not find anything.
    Problem:
    When trying to tighten/compress a King aheadset on a carbon steerer fork, I have to over-tighten it to eliminate play. Steerer ends a 1/4" before the top of the stem, so the top cap is not bottoming out.
    I am using an FSA expanding top cap.
    All my other bikes use star fangled nuts w/o issues.
    What am I doing wrong?
    2003 Pegoretti Luigino & Fina Estampa | 2012 Scott Scale Elite
    wyrd bi ful rd
    Reputation: c_h_i_n_a_m_a_n's Avatar
    Mar 2012
    I am using the No Threadset with a carbon steerer and the steerer is above the top of the stem. No problems with play and compressing as required ... 1.7NM or 15 in lbs, I think.
    I am using a Ritchey Compression device.
    Name:  20121015 ritchey compression device FORUM.jpg
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Your griplock might be binding - maybe a disassembly, grease as per instructions, and reassembly will help. Take care not to shear the o-ring.
    My other 'need to overtighten' scenarios have always been about something being slightly out of alignment - a cup possibly, but most often the crown race or baseplate not dead flush on the crown - a bit of paint, a speck of dirt - it takes very little to create a problem.
    A good habit is as hard to break as a bad one..
    Oct 2004
    Quote Originally Posted by c_h_i_n_a_m_a_n View Post
    I like the knurling on that. It looks much better than the FSA I have. Thanks!
    Quote Originally Posted by danl1 View Post
    Thanks! I took it all apart and it seems clear. The o-ring is still annoyingly tight. The cups and crown race were installed by a shop and look and feel OK (anytime I have installed headsets using ghetto methods the steering has been noticeably wonky).
    wyrd bi ful rd
    Mar 2012
    Star fangled nuts works so well, we do not give enough credit to it.
    There are a lot of problems with various compression nuts for carbon steerers. Usually they will not get a good grip and slip as you compress. The Ritchey in my case, I get to the recommended torque before any slipping.
Sea Otter Classic
Contest
