Results 1 to 5 of 5
    Jul 2011
    Clamp-on rack on ti seatpost?
    I have a 2002 Litespeed Classic with a Litespeed ti seatpost. I'd like to put my clamp-on rack (not quick release) on the bike. Am I looking at disaster? I have old aluminum seatposts that I can swap out if I really have to but I'd rather not if I don't have to. Thanks in advance for your opinions.
    Reputation: Kontact's Avatar
    Apr 2011
    Opinion:
    That's a nice seat post with a nice finish. If you are permanently installing a heavy rack, why do it on a nice post? Screw up the finish on a Kalloy instead and keep the Ti post for when you have reason to remove that thing again.
    It isn't like you need the weight savings when you're using a rack.
    If this was a QR rack I could understand it, but you're going to have to remove the post anyway to install the rack, right?
    pmf
    pmf is offline
    Quote Originally Posted by Kontact View Post
    Opinion:
    What he said. I used to have a rack that clamped onto the seatpost (no where else though). I found it useful to have a dedicated post and saddle just for the rack. I also had a post and saddle for times when I wanted to ride the bike without the rack. Just pull one off and put the other on.
    Reputation: looigi's Avatar
    Nov 2010
    I see no reason to not put the rack on your ti post. However, one alternative to consider is the Arkel Randonneur rack, which hangs from the seat rails and rests against the seat post with a rubber clamp.
    Jul 2011
    "you're going to have to remove the post anyway to install the rack, right?" No removal of seatpost is needed to install the rack. Having said that, I think I'll go with your suggestion and do what pmf suggests. It's not like I have to buy anything. I have plenty of seats and posts. Thanks you both for your replies.
  1. R3 seatpost clamp failure and seatpost damage
    By skygodmatt in forum Cervelo
    Last Post: 12-04-2011, 02:16 PM
  2. P-clamp lower rack mounting?
    By Drew Eckhardt in forum Commuting, Touring and Ride Reports
    Last Post: 08-10-2010, 11:03 AM
  3. Clamp on rear rack
    By Aspen in forum Commuting, Touring and Ride Reports
    Last Post: 01-26-2008, 08:51 PM
  4. Replies: 2
    Last Post: 12-28-2004, 08:29 AM
  5. Can a rack clamp to a carbon seat post?
    By EWF in forum Components, Wrenching
    Last Post: 05-17-2004, 05:42 AM
Sea Otter Classic
Contest
