Results 1 to 14 of 14
    MWT
    MWT is offline
    Nov 2002
    Clamp-on v. braze-on front derailleur
    I'm sort of embarrassed to ask this, but can I simply remove the clamp from a clamp-on derailleur and mount it to a frame with a braze-on front derailleur tab? Is there a special nut or washer required?
    Thanks in advance.
    Not a rocket surgeon.
    Nov 2008
    The clamp dosent come off a normal clamp on derailuer.
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Quote Originally Posted by tihsepa View Post
    Or phrased the other way, if you can, then yes.
    A good habit is as hard to break as a bad one..
    Jan 2010
    Quote Originally Posted by danl1 View Post
    and no to the last question
    There's sometimes a buggy.
    One.
    Sep 2010
    Quote Originally Posted by MWT View Post
    Thanks in advance.
    A true clamp-on will have the clamp integrated with the derailleur.
    like this
    A braze-on can use an adapter when the frame itself does not have a braze-on mount
    like this
    If your front derailleur is like the first picture, then the answer is no. If your front derailleur is mounted on something like the second picture, then the answer is yes.
    MWT
    MWT is offline
    Nov 2002
    I have two bikes with DA 7800 front derailleurs - one braze-on and one clamp-on. I'm 99% sure the clamp-on is a braze-on plus non-integrated Shimano clamp.
    Feb 2002
    You're confused. If the "other" derailleur is attached to a separate clamp as you describe then it is simply a braze-on derailleur used on a frame that doesn't have a brazed on mount, so they used the adapter clamp.
    Reputation: velodog's Avatar
    Sep 2007
    I was able to find a badly worn braze on chorus frt. derailer and remove the braze on head. I was then able to remove the clamp from my clamp on derailer and replace that with the braze on head from the wore out derailer. It was the cage that was wore out, leaving the head in good shape.
    I don't know what kind of components you have, so this may or may not be able to be done to yours.
    Pg.34 has the exloded diagram, if I did this right.
    http://www.campagnolo.com/repository...s07_A-0307.pdf
    Feb 2002
    True that if you have two derailleurs, one braze on and one clamp on, you can disassemble them and swap parts around to do what you did. That is not what the OP is asking about.
    Sep 2007
    He wanted to know if he could use his clamp on by just taking off the clamp, or if he needed a special nut or washer. I told him how it could be done, with a little more than a nut or washer.
    The OP didn't say if it was a clamp on derailer or a braze on derailer with an adapter. I assumed that it was a clamp on derailer
    He asked a straight foreward question and I tried to give him an honest answer on how he could make it happen.
    I'm sorry if you were upset with that.
    Really, I'm not sorry.
    Feb 2002
    I'm not upset. I simply pointed out the OP's question was "can I simply remove the clamp from a clamp-on derailleur and mount it to a frame with a braze-on front derailleur tab?" I agreed with your explanation of a possible way to use some parts of derailleurs to make this work.
    Nov 2008
    This is why I always buy braze on derailleurs. I can swap them to any bike with the right clamp.
    Embrace the fact that everyone on these forums has their own unique desires, needs, experiences and environment so what works for you may not work for others.
    Reputation: PlatyPius's Avatar
    Feb 2009
    Re: Clamp-on v. braze-on front derailleur
    Quote Originally Posted by Maximus_XXIV View Post
    Same here. Plus you can more easily mount a chain watcher thingie.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Jan 2012
    Thanks in advance.
    Oh, you'd have to be a special nut alright.
    New FDs are pretty inexpensive relative to the rest of the stuff we stick on bikes. I just bought a new one last time I had that problem and... I'll never buy a clamp on again as as result.
  1. Clamp-on vs Braze-on front derailleur
    By alaris in forum Components, Wrenching
    Last Post: 10-06-2010, 07:07 PM
  2. Braze-on front derailleur with a clamp? Why?
    By hobiedog in forum Components, Wrenching
    Last Post: 09-27-2009, 07:39 PM
  3. Front derailleur braze-on to clamp-on?
    By kungfugrip512 in forum Components, Wrenching
    Last Post: 05-02-2007, 10:18 AM
  4. Clamp-on vs braze-on front derailleur
    By Cal_Biker577 in forum Components, Wrenching
    Last Post: 10-10-2006, 10:02 AM
  5. front derailleur clamp to braze on?
    By physics_nut in forum Components, Wrenching
    Last Post: 02-15-2004, 07:25 PM
Sea Otter Classic
Contest
