Results 1 to 24 of 24
    Apr 2011
    Compact drop handlebar question
    I'm looking to replace my handlebar. I went to 3 LBSs to get a closer look and noticed that those so called compact (or shallow) drop handlebars are mounted on cyclecross bikes but not on road bikes. Is there a reason for it? Also, what are the advantages and disadvantages if used on road bike?
    Thanks in advance.
    Reputation: looigi's Avatar
    Nov 2010
    That's counter to my experience. It seems just about all new road bikes have compact bars. I guess it depends where you draw the line between compact and non-compact.
    It depends on how you ride and you're preferred setup. I ride with my bars pretty low so bars with a big drop would put me too low in the drops which is why I like compacts.
    Bianchi-Campagnolo
    Reputation: kbwh's Avatar
    Go to Steve Steve Hogg's blog. He explains very well why he recommends compact bars like 3T Ergonova, FSA Compact and Deda RHM.
    They do anything just to win a salami in ridiculous races. I take my gear out of the car and put my bike together. Tourists and locals are watching from sidewalk cafes. Non-racers. The emptiness of those lives shocks me. It was the illest of times, it was the dopest of times. And we looked damn good. Actually the autobus broke down somewhere on the Mortirolo.
    Reputation: stevecaz's Avatar
    Feb 2005
    In the past, handlebars never were considered or used in fitting a bike since the dimension ranges didn't differ much. Now with all the reach and drop options, they are an integral part of how a bike fits and feels.
    Just one case in point for me - I have long femurs so my saddle setback is big. This places me further away from the bars so I can't have too long a reach and top tube. Fortunately have a 72.5 degree seat tube to help with this. On my bike a stem length of 100mm places the hoods at a comfortable torso reach with "standard" bars (~85mm reach). However my long femurs then graze the backside of the handlebars on climbs. To fix this, I installed a 110mm stem which moves the backside of the bars away, and a compact handlebar with a short 73mm reach to bring the hoods back to the same position.
    Cyclocross is not aerodynamic critical, so having a smaller drop is easier and a slightly more upright position with a shorter hood reach is usually preferable to more people, so OEM handlebars are spec'd to the majority.
    Jul 2011
    Compact bars allow us average riders to spend more time in the drops.
    Reputation: wibly wobly's Avatar
    Apr 2009
    The actual drop distance on compact bars isn't what won me over. What I really like about them is the angle my wrist sits when they're in the drops. On most other traditional and anatomic bars my wrist isn't very straight. With the FSA and 3T compact bars, they are. So they're a lot more comfortable for me to be in them.
    Mar 2011
    compact bars have become more common due to the trend of everyone having too much saddle to handlebar drop in order to look 'pro'.
    if the bars are too low to begin with, well then the drops on standard bars are way out of reach.
    May 2009
    I like how flat I can make the ramp, and the flat transition from the ramp to the brake hoods. (FSA Compacts.) The relatively lower reach is nice because my road bike is a little big for me, but I think if I downsized the road bike, I'd probably keep the bars and run a longer stem. (Or not.)
    I like the flare. It keeps the corners of the bars clear of my wrists when I sprint. It's also sort of cool to have the narrower bars I like for distance at medium effort and a little extra leverage, both on the same bike.
    Converted Runner
    Reputation: aengbretson's Avatar
    Sep 2009
    I too like how I can create a flat ramp (well actually there is a slight upward angle from my bars to my levers, it gets both my drops and hoods in my preferred position), but I still prefer the flat lower section of a classic bend bar. I don't find there is much of a difference in access to the brakes and shift levers when comparing my classic bend road setup to my compact CX one. I spend most of my time on the hoods in CX anyway, unless there is a very long straight that goes into the wind.
    To directly answer the OP's question: the advantages are down to personal comfort. Some riders want their hoods to be very low but that could limit access to the drops so a compact bar is a good choice there. They are also designed with modern integrated levers in mind to create that flat transition. Look at bike with classic bars and you'll usually see some kind of angle between the bars and the hoods.
    Nov 2009
    Quote Originally Posted by captain stubbing View Post
    seems like someone is trying to sound 'pro' by stating their use of a deeper drop handlebar
    this info might be helpful, i got it form another thread on RBR: Road Drop Bar Geometry : La Rueda Tropical
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by tfinator View Post
    Well, there is some truth to the captain's assessment of the compact drop handlebar popularity. As one astute RBR member put it recently, "...those silly modern 'compact' bars, [whose] drops are way to short to be useful for anything other than giving some wanker the appearance of riding a 'real' road bike."
    Apr 2011
    Nice link. Thank you.
    Bianchi-Campagnolo
    Quote Originally Posted by wim View Post
    A statement that is so full of bull that it can only be two:
    1) Narrowmindedness, making the person not able to understand the great leap in ergonomics the modern integrated controls have made possible.
    2) A joke.
    Now over to Rueda Tropical again:
    Bike Fit from Coppi to Contador : La Rueda Tropical
    One note though: Contador doesn't seem to like to use his drops much, which probably means he's just a poser wanting to look pro.
    Hucken The Fard Up !
    Reputation: Salsa_Lover's Avatar
    Jul 2008
    This!
    To me, just give me classic bars, sloping down round bend, flat hoods lower than the tops, round hooks and flat low drops parallel to the floor.
    Try it. Classic rounds or Italian shallows, set them up right. Then you'll realise how silly are those compact bars.
    Quote Originally Posted by zank
    They're just bikes. Ride 'em in the rain, salt, snow and crap to fully appreciate them.
    Quote Originally Posted by Sean Kelly
    The thing about the cold is that you can never tell how cold it is from looking out a kitchen window. You have to dress up, get out training and when you come back, you then know how cold it is.
    Mar 2011
    haha....nah i actually use compacts myself!
    my orig statement wasn't necessarily a criticism, and with my reference to 'look pro' i'm not inferring that the person is a 'poser'. Just saying that more drop these days is prob due to the fact that 'pros' have their bikes set up that way.
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by kbwh View Post
    1) Narrowmindedness, making the person not able to understand....
    My apologies to the person I quoted.
    Apr 2009
    compact is the way to go..Here's why-with the shallow drop you can lose the spacers on the headset to achieve the same drop with traditional bars. That and the tighter bend will stiffen up the front end noticeably . Also, for the weight obsessed, few grams lighter. If you need a traditional look get a model that has a more rounded grip area. Traditional bars are not as stiff because more material and large bends.
    Sep 2011
    I am planning to go to a compact bar in the next few weeks, so thanks to all on this thread for providing good information.
    Feb 2002
    good info here from Competitive Cyclist review FSA Omega
    Nov 2011
    Quote Originally Posted by stevecaz View Post
    I have a similar build and that's the biggest reason why I like compacts. In addition, I prefer the flatter tops that follow the brake levers. They offer more contact area that traditionals, so my hands can ride the tops longer.
    EMR
    EMR is offline
    Apr 2002
    I ordered the Omega compact a few days ago, can't wait to try it.
    Reputation: Ventruck's Avatar
    Mar 2009
    Thread in question? Why Compact Handlebars?
    My comments on what good use they are would echo from that thread: in short the reach parameters between tops, drops, and hood is less different/radical. There's no rule of thumb insisting how different they should be, but I wouldn't be surprised if one were to find themselves with one parameter in a perfect spot at the cost of everything else being too far/near. With compact bars you could effectively change hand positions with less dramatic change for the rest of your body.
    all the gear - no idea
    Sep 2003
    omega good
    Quote Originally Posted by EMR View Post
    You'll love em, cheap and good - love mine - saw plenty in use by (female!) pros at tour of flanders last spring... so hey, compacts aren't just for w***kers, they are also for girls ;)
    I ride in circles..
    Reputation: ZoSoSwiM's Avatar
    Mar 2008
    I have the FSA Pro compacts on my SuperSix.. Love the curve and the transition to my hoods. Much more comfortable than my 3T ergo bars on my old bike.
    ~ Long Live Long Rides~
  1. Which handlebar similar to FSA Vero Compact Drop?
    By skyliner1004 in forum Save Some Weight
    Last Post: 08-26-2010, 09:11 PM
  2. Handlebar question - bullhorns with our without a drop?
    By jefftheo in forum Fixed/Single Speed
    Last Post: 08-24-2009, 06:46 PM
  3. Handlebar drop
    By PSC in forum General Cycling Discussion
    Last Post: 03-22-2008, 09:44 PM
  4. Another handlebar drop question
    By ilium in forum General Cycling Discussion
    Last Post: 03-14-2008, 03:51 PM
  5. Handlebar question: hoods drop
    By Lionel in forum Components, Wrenching
    Last Post: 09-29-2007, 03:33 AM
Sea Otter Classic
Contest
