Results 1 to 9 of 9
    Jun 2018
    Converting dura ace 7700 to 11 speed?
    Hi,
    Does anyone know if a ultegra 6800 freehub body will bolt to an old dura ace 7700 (9 speed) hub? I'd love to not have to lace up or buy a new wheel.
    Thank you!
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    Nope.
    Trying to cram the rest of my life into the rest of my life!
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    When you make the jump to 11-speed on Shimano, you make the jump to new wheels.
    Banned forever.....or not
    Aug 2002
    Unless you have some Mavic wheels....Otherwise, you are S.O.L.
    Dogbert.
    I>U
    Reputation: Notvintage's Avatar
    May 2013
    Quote Originally Posted by bigdork View Post
    Hi,
    Thank you!
    jesus man, cheap much? Open your wallet for the 21st Century. Lol
    pmf
    pmf is offline
    Quote Originally Posted by jetdog9 View Post
    And that's why I went Campy when I converted my bikes over to 11-speed. Shimano didn't have to do this. Campy didn't when they went from 10-speed to 11-speed.
    Off the back
    Reputation: fast ferd's Avatar
    Jan 2009
    Quote Originally Posted by pmf View Post
    Except you will need to change hubs if you go to Campy 12-speed...
    pmf
    pmf is offline
    Quote Originally Posted by fast ferd View Post
    I skipped 10-speed and will probably do the same with 12-speed. I just sold 7 sets of 8/9/10 Shimano compatible wheels that were completely useless to me.
    Aug 2002
    The reason that it won't work is that your 7700 hub is made to work with an "old school" standard diameter axle, and the 6800 hub use the new oversized stepped axle...
    BUT.
    I just remembered that the first generation shimano 105 11 speed hub uses the "old school" type axle. There is a possibility that the 105 11 speed freehub MIGHT fit on a 7700 hub......If it does, you'll still have a problem. Since the freehub is longer, you'll have to use different spacers to move the hub over a few mm to the left......The wheel will have to be redished to center it in the rear triangle. With all of this work to possible make it "MIGHT" work, it would be easier to just buy a new wheel.....
    Dogbert.
    I>U
  1. Dura Ace FH-7700 vs HB-7700 rear hub
    By angelonc in forum Wheels and Tires
    Last Post: 05-15-2017, 04:46 AM
  2. Dura Ace 9 Speed 7700 Compatible Chainrings
    By SoquelMTBR in forum Components, Wrenching
    Last Post: 09-14-2016, 08:11 AM
  3. compact crankset compatible with Dura Ace 9-speed 7700
    By deskdiver in forum Components, Wrenching
    Last Post: 09-30-2015, 09:08 AM
  4. Dura Ace 7700 9 speed
    By wannaXbe in forum Components, Wrenching
    Last Post: 06-02-2014, 11:54 AM
  5. Replies: 8
    Last Post: 09-12-2013, 04:12 PM
