Results 1 to 25 of 26
    Jul 2014
    Cracked aluminum steerer?
    This vertical line, which isn't visible unless you point a flashlight at it and can't be felt with a fingernail, bothers me a bit. Is it possible it might be cracked / weakened? Or is it some kind of weld join?
    jta
    jta is offline
    Jun 2012
    Maybe remove the top cap, and have look to see if the carbon fiber is cracked from that angle?
    Edit: sorry, you did mention the steerer tube is aluminum. Definitely need caffeine. Still, worth a look?
    wim
    wim is offline
    Feb 2005
    It's amazing to me you didn't remove the spacers and the stem before taking that picture. I hope you weren't planning to ride that fork after someone on the internet typed "not to worry, just a scratch."
    Whatever it is, I'd not ride that fork. Aluminum can progress from an imperfection to complete failure in a matter of weeks and sometimes just days. And steerer failure can be deadly, believe me.
    Jul 2014
    I was in a hurry before leaving for work, just wanted some quick first impressions. This bike isn't hitting the road before May, so I will definitely take a better look at the whole steerer.
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by ToiletSiphon View Post
    OK, makes sense. It's worrisome that you can't feel that line. Were it a scratch, you'd feel it because material is gouged out in a scratch. A crack can have both surfaces on either side of it completely flush with one another.
    What's odd is the location and direction of the mark. The highest stress on steerers by far is the area just below the lowest spacer, and steerer cracks generally run circumferential. When you pull the stem, check (by feel) if there's a slight burr on the lower inside edge of the steerer clamp that matches the location of the mark. If there is, it could be an installation scratch so slight you can't feel it. Could be--I'm not saying it is!
    'brifter' is a lame word.
    No grease on those threads?
    I work for some bike racers
    and a bunch of skateboards
    Oct 2013
    Also looks like the top bolt has been torqued to a much higher value than the bottom bolt. Usually when torqued properly, the upper and lower gap that shows the bolt threads are equally wide.
    Jul 2014
    Quote Originally Posted by Z'mer View Post
    Both torqued to 5Nm by me (only thing that I did as my LBS didn't perfectly align my stem after last maintenance) . Maybe the expander plug was overtorqued and bulged the steerer at the location of the bottom bolt, explaining the difference?
    As for the grease, there is some but imo not enough.
    I'll take it to the shop tonight, doesn't look good the more I think about it.
    You still think that steerer is aluminum?
    Jul 2014
    I'm not so sure anymore! I thought it was because Cannondale advertises the Synapse as having carbon fork and the Synapse Hi-mod has having a FULL carbon fork... That being said it looks an awful lot like some carbon matrix under a bright light!
    Anyways turns out it was a false alarm. Every Synapse in the shop had the exact same line on the steerer. So it's some kind of joint or a line between two carbon sheets.
    A valid point was raised tho about the top and bottom bolt not looking like they have been torqued the same. The bottom bolt is at the location of the expander, while the top one has a part of the stem clamping on nothing (Cannondale, in their manual, states that 2-3 mm of void should be left between the top of the steerer and the top cap). So I guess that explains in part how much every screw is screwed. Just to make sure I would not deform the tube, I torked the bottom bolt to 5Nm and the top one to 4.5Nm. It doesn't sit perfectly straight but it's better and the tension difference must be negligible enough not to have any ill effect.
    Dec 2006
    Here's how to test whether that's a legitimate crack.
    Remove the fork an mount it in a bike stand, vise, whatever, so the steerer is horizontal.
    The suspect crack should be facing the floor. Place a piece of invisible scotch tape over the crack.
    Now flow a little colored fluid like Liquid Wrench so it puddles in the trough of the steerer on top of the suspected crack. Try to prevent it from flowing over the end of the steerer.
    Let the setup sit for an hour. Without removing the assembly, take a peak to see if the scotch tape has captured some of the fluid if it flowed through the crack.
    This method worked for me; it proved my headtube was cracked.
    Attached Thumbnails Attached Thumbnails Cracked aluminum steerer?-img_5112.jpg
    Oct 2013
    With that difference in gap, I would put a spacer under the top cap to get that top bolt away from the top of the fork. I cannot believe that the top of the carbon tube is deflecting that much to reduce the dia of the steer tube without a failure.
    BANNED
    Jul 2014
    Maybe it's not the tube itself that's deflecting, might just be something with the steerer itself. The idea of putting a spacer on top of it sounds fine but Cannondale explicitly advises against it as it's supposed to prevent proper functioning of the expander and top cap
    wim
    wim is offline
    Feb 2005
    I must be missing something--when did this steerer change from alloy to carbon? Old man here, it's easy for me to misread stuff now.
    Jul 2014
    Quote Originally Posted by wim View Post
    Honestly I just don't know what material it really is. Always tough it was alu but by the look of it it might be carbon.
    Jul 2014
    That's carbon right? I the inner part is a different color, is this usual?
    That'd be carbon. Nothing unusual there.
    Jul 2014
    Anything wrong with having a small imprint of the edges of the stem on the steerer? (see horizontal line slightly below middle of steerer - it follows exactly the clamp pattern of the stem)
    Can't be much worse than what carbon paste does on a seatpost, right?
    Not a problem.
    Jul 2014
    Well, tried to flip my stem today to see if it was caused by the stem itself. Even with the stem flipped, the spacing is still wider at the bottom. I'm puzzled... Might be caused by the expansion plug?
    Inspected the steerer, it's super straight, no bulging or anything wrong.
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    If it's caused by your plug you could try a longer one. Couldn't hurt. Specialized, among others makes one.
    Trying to cram the rest of my life into the rest of my life!
    wim
    wim is offline
    Feb 2005
    The assumption made by someone above that one bolt has been torqued to a higher value than the other could be incorrect. It's based on the belief that the open spaces through which you can see the screw threads should be of exact equal width. If those spaces are not of equal width with the screws completely removed, there's no problem. There's no need for tight tolerances in that area of the stem, so the stem could have come a bit "unequal" right from the factory.
    Also keep in mind that 5 Nm on one screw may not generate the same clamping force than 5 Nm on the other. If, for example, there's more grease under one screw head than under the other, clamping forces at 5 Nm would differ and you would see that difference in slot width.
    If you're concerned about these these slots not being exactly equal (I wouldn't be), you need to measure them carefully. Optical illusions play tricks on you, and you certainly can't trust photographs because you don't know if the camera was exactly centered and level.
    Sep 2015
    On two of my bikes with carbon steerers, the stem bolt spacing is wider at the lower bolt because the FSA expansion plug is located at the lower stem bolt, which is prevents deflection (pushing out against the stem). Both stem bolts torqued to 5.5 nm per Thomson X2 stem instructions.
    I've removed the stem several times to lower my stem and the carbon steerer hasn't bulged or permanently deformed. As long as you don't tighten the stem bolts above the maximum allowable torque, it shouldn't damage the carbon steerer tube.
    Jul 2014
    Quote Originally Posted by ra21benj View Post
    It's seems to be exactly what I see with my bike (have the FSA plug). While it seems to be 'normal' for this hardware, it still bothers me a little, since the increased support the lower stem bolt has compared to the upper one means that the steerer is not loaded in the same way at both bolts,which is less than ideal on any tube. I'll try with a longer expansion plug.
    Jul 2014
    Not a problem.
    I guess the vertical band of matrix-like pattern we see going all the way up, on the right part, isn't anything special either? Do you know what causes this?
  1. Replies: 3
    Last Post: 04-17-2014, 10:25 AM
  2. Cracked Carbon Steerer?
    By spastook in forum Bikes, Frames and Forks
    Last Post: 05-10-2010, 09:34 PM
  3. Cracked Steerer?
    By hfc in forum Components, Wrenching
    Last Post: 12-11-2006, 07:05 AM
  4. cracked steerer
    By Bonked in forum Components, Wrenching
    Last Post: 10-02-2004, 08:53 PM
  5. how to fix a cracked steerer
    Last Post: 04-29-2004, 05:26 AM
