Results 1 to 5 of 5
    Jun 2011
    Cracked carbon fiber frame - repairable?
    Hey guys,
    Yesterday I was loading up my Avanti Cadent 3.0 2010 roadie on a steep hill and all of a sudden I heard a *crack*. I stopped and noticed that the front inner chain ring had snapped in half! As a matter of fact, what had happened is that a few of the bolts holding the inner chain ring on had obviously worked themselves loose over time (something I hadn't even thought to check regularly) and so eventually the chain ring had too much pressure (on the hill) and simply buckled and cracked. That would be fine if that was the only problem, but it turned out that a small 2 inch piece of the chain ring broke off and lodged straight into the carbon frame, creating a thin hole about half an inch wide right at the base of the frame. I have done a photoshop mockup of the location and approximate size of the crack on one of the avanti black frames as I don't have any photos of it. The white crack indicates the approximate size of the crack which has gone right through into the middle of the frame. See the link: http://i219.photobucket.com/albums/c.../Bikecrack.jpg
    As you can see it is right at the base of the frame.
    Now this kind of problem isn't naturally covered on the warranty so I have been given the option to pay for the replacement Cadent frame which will cost be around $1300. Seems like such a loss of money since I'll be getting back the same bike as before in essence. Anyway, my issue is what to do with the old frame? Is there a way I can repair it myself? Or would it be better to sell it on to someone who might be happy to fix it and use it? Should I repair it myself and hold off on getting the $1300 replacement frame?
    Cheers
    Dan
    Jun 2011
    Contact a frame repairer for a quote from what I have seen posted they can do very good work
    Jan 2007
    That seems to be a doable repair and worth seeking out Cafee or another specialist in carbon fiber. My quess is that it will cost around 250-500 for the repoair, much less than 1300.
    great gear,lowest prices
    Reputation: L9Sports's Avatar
    May 2012
    indeed, sounds repairable.. "calfee" does a great job and you should expect to pay more along the lines of 800 and being without your frame for 6+ months.
    Great Gear, Lowest Prices: levelninesports.com
    Reputation: carveitup's Avatar
    Oct 2008
    I've never had one repaired but people have also spoken highly of Spyder in California. Seems to be significantly less $$ than Calfee. Calfee does have a good rep, though.
Sea Otter Classic
Contest
