I went to install my new Deda Zero stem, The stem say max torque of 8NM. That seemed a bit high in my mind. SO went with 5NM same as the Ritchey stem uses thatw as just on there.
So Install it and wehn I tightend the bottom right bolt I heard a cracking sound. I looseded eveyhting up and there is a hairlie crack in the mesh reinforcement area the length of the stem clamp.
I have installed a WHOLE bunch of CF bars and nothign ever like this has happened. Just what I need with a long wekend coming up and a century in 3 weeks, downtime. Well to the back-up bike....
I ordered a new bar tonight and will deal with this on Tuesday with Syntace USA and or Performace Bike. I bought the bar new from Performance in March. I have never crashed these bars either. Maybe just a bad bar or something.....
Ouch....sorry to here about that. I won't even bother to ask the usual question because I know you have installed these sort of things before. Hopefully a quick replacement and fix and back on the primary bike for you. Any pics available so we can see what the heck happened or is it too small to really show? Carbon is always such a pain to photo well.
I'm curious, Deda uses 31.7mm, but the Syntace bar is 31.8mm. Doesn't sound like a lot of difference, but I wonder if you compressed the carbon bar too much when torquing the stem bolts down on an ever-so-slightly fatter bar?
Bolts got stripped even though torque was lower than reccomended. I had too saw off them off.
The stem is bac to Extralite foe evaluation. I wanted to try something different than the Ritchey 4-axis as the face plate finish SICKS donkey balls!
I think the bolts are too soft and EL says I have a crappy TW. :mad2:
Now it looks like USPS lost it. I am having a bad week...:cryin:
The Deda SC in 120mm came in at 118g. Looks really nice on my bike.
I just spoke with Syntace/Magura about this issue. They said they were having issues with some Racelite carbon bars cracking here the bar drops, not in the stem clamp area where I have mine. The bar is being re-designed by Jo Klieber to fix this. I am not aware of ant recall and they did not say. But id there is any possible need for one, Syntace will do it fast and easy. They had a minor issue with their F99 stems last year and did a voluntary recall and gave you a little something back for you effort (bar/stem combo for $35 off or a Torque wrench and bits for $95).
If you have this bat, keep and I on it when changing tape. If you are that worried about it, contact Syntace and I am SURE they will take care of you. New bars arrive in 3-4 weeks.
I have one coming today and will ride it until the new ones arrive. I have not seen or heard of any cracking issues until mine and when I try to order another pair a few weeks back and what told there was a updated model coming "due to some possible QC issues."
If my position was not so dialed in with the fit/reach of this bar, I might have just ordered an aluminum bar till the news ones arrive.
But Syntace told me to ride the new bar and return it to them when I get my new one on exchange and I should be fine as it's a very minor issues and it's not widespread at all.
A crack like that appears to be the result of a mismatch between the bar and stem diameters, assuming there is no obvious raised edge or burr on the stem. If the bar is too big or the stem clamp too small, you get line contact at the leading edge of the stem and the result is a crack from excessive pressure.
To be safe, when installing a new bar, push it into the stem by hand to see if it catches on the leading edges of the stem. If so, then some shallow angle chamfering of the leading edges may be necessary to eliminate the interference.
Miscalibrated click-type torque wrenches can also be a cause of such a problem. Cheap beam types wrenches are harder to read, but never need calibration. Personally, I've never used either on small M5 or M6 bolts. I use a 4-5-6 Y-style wrench and go by feel.
Thanks. I was worrired as the stem is 31.7 and the bar is 31.8. Syntace has had no known issues with this combo. They also did not reccomend using the 8nm max settign Deda says.
I will check the new bar with the stem today like you said. If there is any issue I will stick withe the Ritchey 4-Axis whcih had none.
The click-type wrench is fr4om Syntace and is certified to be very accurate and is guaranteed to be +/- 4% accuracy.
You know what, I always went with feel on thes elarger bolts and will agin. My Extralite stem requires only 2.5m which is very little as well. I will snug it just enough to hold the bar.
A click-type wrench should be accurate, but they are not failure-proof. They can produce grossly incorrect torques if the internal mechanism malfunctions. Beam types are pretty much foolproof, as long as the pointer aligns with the zero mark. A beam type can be used to check the accuracy of a click type.
Did that crack line-up with the leading edge of the stem, by chance?
I totally agree with Thompson's article but for MTB only. I am a big 200lb+ guy and my riding style puts lots stress on my bikes and never had a failure with carbon fiber seatposts or bars on a road bike.
Thanks for the info DirtBoy/et all...... useful as I was looking to buy some and noticed starbike/weight weenies were showing a delivery date for early december, now I know why and why nobody else has them in stock.... well in Europe anyway
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
