Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
  1. #26
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by Wetworks View Post
    Yes, a momentary loss of resistance wherein my foot kind of clunks the pedal forward, sort of like when you do 1 legged cadence drills with your non-dominant foot, but this is during low resistance.
    Thanks, it's clearer now. What probably happens is that your leg speed slows down briefly, allowing the top run of the chain to go slack. When that happens, you step into thin air until the chain is tight again (sometimes you hear a clunk when the chain snaps tight).
    Many people do this when they're tired and turn a cadence a bit too high. The nerves that coordinate the pedal stroke don't work as well as they should when the body is tired. You may want to ride with a slightly higher gear (at your customary speed), especially when fatigue sets in.
  2. #27
    Reputation: Wetworks's Avatar
    Aug 2012
    Quote Originally Posted by wim View Post
    That's extremely fascinating and insightful! Thank you for that!
  3. #28
    Feb 2002
    As a further comment, this is indeed a neuromuscular issue much more than a crank length issue. You mentioned one-leg drills and I suggest you do more of those. You should also work specifically on increasing your cadence while keeping things smooth. This happens naturally for most people but nearly everyone can benefit from focused drills. Raise your cadence for a minute (or five minutes) and then drop back. Do this multiple times per ride. Focus on "pedaling circles" to keep things smooth and prevent your butt from bouncing on the saddle. All of this will help you a lot more than a change of a few mm in crank length.
  1. Flat Bar Road Bike - Do you go up a size due to the reduced reach?
    By Weaklink in forum Commuting, Touring and Ride Reports
    Last Post: 04-01-2011, 07:26 PM
  2. New Crank Size
    By manonabike in forum General Cycling Discussion
    Last Post: 07-17-2009, 04:01 PM
  3. Flat pedal options for size 14 paws
    By Cervelo-er in forum Commuting, Touring and Ride Reports
    Last Post: 03-23-2009, 08:57 AM
  4. Flat bar vs drop bar - frame size
    By FrankinMich in forum Bikes, Frames and Forks
    Last Post: 11-26-2008, 05:10 AM
  5. Old crank 42t, new crank 39t, cassette size advice?
    By T-shirt in forum Components, Wrenching
    Last Post: 10-29-2004, 03:30 PM
