Results 1 to 8 of 8
    Reputation: redondoaveb's Avatar
    Jan 2011
    Crossing derailleur cables
    I know that there a some people on here that have crossed their derailleur cables at the head tube in order to keep them from rubbing on the head tube. Obviously, they have to cross on the back side of the downtube. Where they cross, they will be touching and rubbing on each other. Is there any concern with premature wear from the friction of rubbing back and forth?
    If you try to fail, and succeed, which have you done?
    pmt
    pmt is offline
    Aug 2009
    Don't do it! Your bike will asplode!
    off the back
    Reputation: rufus's Avatar
    Not so far.
    Figure you'd probably replace them on your own before they could ever wear enough to break.
    Eff the King's Guard. Eff the city. Eff the King.
    Jan 2011
    Quote Originally Posted by pmt View Post
    That was my concern, too much heat from friction. Heat + carbon = asplode!
    Jan 2011
    Quote Originally Posted by rufus View Post
    Not so far.
    Good to know. It sure makes it a lot nicer with them routed on the other side of the head tube. Thanks for the input.
    Jun 2008
    If you get higher end cables with the plastic coating, that will wear through. And of course the guides have to be positioned low enough so that the cables don't rub the frame. I did this on my Cervelo, worked great.
    Feb 2002
    Quote Originally Posted by redondoaveb View Post
    My cables have been crossed for 14 years and about 130,000 miles. No noticeable wear on the cables to date (cables replaced every 30-40K miles).
    Jan 2011
    Yeah, I dug up this old thread. Sounds like the cables crossing isn't a concern at all. Thanks guys.
    Crossing derailleur cables on downtube?
