Results 1 to 25 of 47
    Jul 2010
    Crown race won't fit on carbon steerer
    I'm in the initial stages of a build and I can't seem to get the crown race onto the carbon steerer.
    The fork is all carbon, with a tapered steerer (1 1/8" to 1 1/4"). I've measured the diameter of the bottom of the steerer to be 33.6mm and the inside diameter of the crown race to be 32.9mm. This is a 0.7mm, which could be quite significant.
    So what should I do? So far I see my options being:
    1) Smash the crown race on anyways and see what happens. Maybe heat the crown race first?
    2) Face the inside of the crown race to get it closer to 33.6mm.
    3) Buy a new headset and hope that the new crown race is closer to 33.6mm.
    Any help here is much appreciated.
    Jan 2010
    Cane Creek have the standard 1 1/4" crown race at 33.06 +/- 0.03mm, putting both your measurements outside the limits.
    http://www.canecreek.com/manuals/Hea...ationGuide.pdf
    Not much help I know.
    Some carbon forks (see link) may not use a crown race at all. The carbon bears directly on the inner race of the lower bearing, just as the crown race would.
    There's sometimes a buggy.
    One.
    FTR
    FTR is offline
    Burn baby, burn.
    Reputation: FTR's Avatar
    Sep 2006
    I am going to guess it is a pressfit crown race and if so it is designed to be basically hammered on.
    If it is the headset that came with a Chinese frame then it most definitely is pressfit.
    Jun 2010
    What is the maker of the frame and fork and have you contacted them? I would guess they would exchange them...
    Regards,
    Dan
    Mar 2007
    The correct crown race diameter for a 1 1/4" headset is 33.0mm. The fork you have is slightly over sized. What kind of fork is it? I would contact the manufacturer and see if they can offer an exchange.
    The next option would be to mill (or 'face') the fork down to 33.0. This is a little tricky because if you remove too much material, you're SOL.
    Whatever you do, DO NOT try to hammer the crown race onto the fork as is. That much of a dimensional difference (0.7mm) is too much for an interference fit. You will damage both parts in the process.
    Jan 2009
    Quote Originally Posted by FTR View Post
    The amount of interference for a press fit crown race is typically .05mm, so if the OP is measuring accurately, there's no way the race could be pressed on.
    I suspect that he has a 33mm (nominal) race which should measure 32.95-33.00. If the fork as truly that much bigger there's something wrong with it, unless it came with it's own race.
    The OP might have the option of using a split "crown race" since on most sealed headsets the crown race isn't one at all, but only a centering cone for inner race of the lower bearing.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    FTR
    FTR is offline
    Burn baby, burn.
    Sep 2006
    Quote Originally Posted by TimV View Post
    No way would I be "milling" a CF steerer.
    Also you are assuming he measured everything perfectly.
    You can easily get a variance if you dont.
    Jun 2003
    My Colnago 1 1/8 all carbon fork had to be "faced" with a special tool before the Chris King race could be installed. No problems with the "facing".
    Jun 2010
    Quote Originally Posted by Al1943 View Post
    Was the carbon coated to protect it from moisture absorption?
    Regards,
    Dan
    Jun 2003
    Quote Originally Posted by NEO Dan View Post
    I don't know, you'd have to ask Ernesto.
    Mar 2007
    Just because you are afraid to do something, doesn't mean it can't be done. Assuming his measurements are close (and yes, I did assume that :roll eyes: ), we're only talking about 0.010" to 0.015" of material removal. That's not very much considering the material thickness in that part of the fork probably exceeds 0.250".
    FTR
    FTR is offline
    Burn baby, burn.
    Sep 2006
    Or you could just use the pressfit crown race how it was meant to be used.
    And I am not even going to assume that he knows the difference between .7mm and .07mm.
    Jun 2010
    Yeah let me get right on that, I think I'll send an e-mail to Ernesto...
    But seriously, if you had a spot of bare carbon exposed on your bike due to a tire rub or something of that nature and it failed you'd be SOL in the warranty department. The interesting thing about the crown is that moisture/grease/grit/solvent can accumulate there and not easily be removed if at all while assembled. Washing your bike or getting caught out in the rain are not uncommon. Carbon needs to be sealed to prevent contamination of the layup, you could easily drop the fork and see if it's been sealed up.
    Incidentally I just bought and sent back an Easton fork that had been sanded on at the crown. Easton service e-mailed me a shipping tag within minutes of my calling to ask if they were OK with bare carbon at the crown.
    Regards,
    Dan
    Reputation: Kontact's Avatar
    Apr 2011
    I have a bare carbon Calfee. We've sold multiple bare Parlees and Calfees. Carbon brake tracks are bare. They don't need paint or coatings, because carbon fiber composites consist of nothing more than solid graphite fibers in epoxy resin. There is nothing there that can absorb liquids.
    Your post wins the prize for craziest carbon fiber misinformation of the year. Congrats.
    Jun 2010
    typo
    Quote Originally Posted by Kontact View Post
    OK then answer this question; if you get the frame wet for more than a moment and wipe it off does it look completely dry or like it was wet?
    Regards,
    Dan
    Jun 2010
    Exposure to UV is also bad for some resins used in the manufacture of carbon fiber parts if you care to look around...
    Regards,
    Dan
    FTR
    FTR is offline
    Burn baby, burn.
    Sep 2006
    Exposure to UV is also bad for carbon if you care to look around...
    Yes it will assplode!!!
    And melt in the rain.
    Jun 2010
    Sorry FTR,
    I understated the position, now corrected above... : )
    Steel is real, LOL
    Real heavy...
    I ride carbon - really
    Regards,
    Dan
    FTR
    FTR is offline
    Burn baby, burn.
    Sep 2006
    Me too, and ti.
    One for probably a lot longer than the other before it needs replacing.
    Apr 2011
    The surface is fiberous and water sits on the surface differently than something slick. But it isn't absorbing anything, it just has more surface area.
    Micarta is a composite made from fabrics and paper. The linen and canvas micartas used for knife handles will absorb some water into the fibers, but it doesn't hurt the epoxy structure.
    By contrast, nylon actually does break down chemically in the presence of water, but that's still not a problem that anyone worries about.
    UV can be a problem with everything - including paint. But UV doesn't damage the carbon fibers, and carbon composites are opaque, so how much damage could UV do to a composite as a whole?
    Now that I've answered your questions, how about sharing a source for this knowledge nugget for absorbent carbon fiber problems?
    Reputation: gamara's Avatar
    May 2002
    Not to detract from the OP question but people have some very weird concepts about carbon. To some people its indestructible & to others its as fragile as glass. If people actually watch how a carbon frame is constructed, you would see that there is quite a bit of sanding involved. People with carbon tubular rims use solvents & glue on bare carbon all the time. So I don't think anything gets "absorbed".
    What people get confused about is when they think that something like a scratch in the carbon clear coat will lead to failure. Carbon failure is usually due to stress risers acting on an area over time. This could be anything from impacts to over tightening something.
    As for the OP, there was the recommendation of milling the area down. If the clear coat is too thick, there is nothing wrong with removing just enough of it to help ease installation.
    Reputation: Bill2's Avatar
    Oct 2007
    I had the same problem. Used very fine sand paper and spent an hour or two delicately removing the excess material from the circumference of the 7mm high shoulder at the base of the steerer. Pressed the crown fork race on and it's been working great for the past couple of years.
    Jun 2010
    It's simple; carbon should not be exposed to contaminants if possible. Giving it a protective coating is normal and correct practice. I do have some practical experience with raw carbon fiber, you reminded me of my 940CF D2 this thing has shed many little pieces of it's surface over the years...
    Getting carbon fiber splinters in your fingers sucks
    Regards,
    Dan
    Jul 2010
    Thanks for the replies and insight everyone.
    Here's the answers to a few questions:
    - Bike is a BMC Team Machine SLR01.
    - Crown race is press fit
    - There is no clear coat on the steerer, so if I were to sand it down, I would be sanding the bare carbon.
    Any objections to reaming the inside of the crown race? I can get a new one from FSA for $16 shipped if I accidently take out too much material.
    Mar 2007
    Quote Originally Posted by Kneedragon View Post
    How do you plan on doing this? Do you have a lathe? The reason I ask is that if you just plan on using a file or sandpaper, you going to be there for a while. Also, the result will be neither very pretty nor round.
Sea Otter Classic
Contest
