Page 4 of 5 FirstFirst ... 2345 LastLast
Results 76 to 100 of 116
  1. #76
    Feb 2010
    If you're a triathlete, or if you know any triathletes...please, tell them to pay more attention to their equipment. I work on dozens of bikes that belong to 'competitive' (not sure what that means to them) multi sport athletes and only one of them gets proper care and maintenance.
    Most of them seem to train indoors because we all know there aren't enough hours in the day to train for 3 sports outdoors, work, and have a life. This means they sweat on their bikes more than if they were outside. Most seem completely oblivious to the concept of 'corrosion', even after we've told them many times. The following photos were taken just a few months after the last service I did on this bike. The brake cables were so corroded the lever wouldn't return and I had to spray the rear wedge w/ PB Blaster more than once before putting it in the soft jaws to yank the cable out w/ pliers. The bars were wiped down w/ WD after the last cleaning, same corrosion is back.
    We used to have a triathlete who came into the shop who didn't use chamois cream, he just used vaseline. He smeared it all over the bottom of his seat. Every so often you'd forget when he brought his bike in and stick your hand under there to pick the bike up, and immediately go wash your hands.
  2. #77
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by masont View Post
    WTF! How much freaken Vaseline did he use that it oozed through his shorts and under his seat? Just reminds me to examine carefully before I sit on anything.
  3. #78
    A wheelist
    Reputation: Mike T.'s Avatar
    Here is a pin out of a chain on a bike I fixed. The chain was elongated a whopping 3/8" over 12" where 1/16" is usually the "replacement" limit. It was on a recreational rider's mountain bike. The chainring teeth were worn to nubs. He stood on the pedals to accelerate and the chain skipped a few chainring teeth. He went over the bars. I replaced everything - chain (duhh!), all 3 rings and cassette.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with motivation, information and resources.
  4. #79
    Russian Troll Farmer
    Sep 2016
    Quote Originally Posted by Mike T. View Post
    Acchhhh the photo didn't upload. I'll try to fix it laterzz.
    Downsize the photo. There is a limit on the # of pixels.
    "L'enfer, c'est les autres"
  5. #80
    A wheelist
    In this case it was nothing to do with the pic size or # of pixels. The full size of that pic is a tiny 3KB. It's the RBR photo uploader that isn't working. I uploaded to Photobucket instead.
  6. #81
    'brifter' is a lame word.
    This could end up being expen$ive...
    It's very happy right where it is and I haven't started thinking about whether I want to go directly to the 'power tools' solution.
    I work for some bike racers
    and a bunch of skateboards
  7. #82
    Reputation: Wetworks's Avatar
    Aug 2012
    And maybe replace it with a thru-axle that doesn't require a hex wrench.
    Jeez, that sucks, some nice DA rotors on there, too. What kind of bike?
  8. #83
    Oct 2002
    would a JB Welded wrench work? TBH though it's shagged.
  9. #84
    Reputation: velodog's Avatar
    Sep 2007
    Will an easy out, screw\bolt extractor, work?
    Too old to ride plastic
  10. #85
    Quote Originally Posted by DaveG View Post
    Why do people want to convert others to their chain lube regiment? Its like chain lube Jehovah Witnesses.
    Quote Originally Posted by SPlKE View Post
    Exactly. That's why I keep telling people... forget the homebrew, forget all those fancy new chain lubes. Get ProLink, the one and only Best Chain Lube. ProLink... It's got what chains crave.
    I'm really not sure what I'm going to try first. The right side is the threaded end and that's what is stuck. The left side is the tool end. I'd like to try from the stuck end if possible but not sure what to put in there that won't slip/spin.
  11. #86
    Sep 2007
    How about a self tapping screw\bolt that would bottom out and allow you to keep tightening, pushing \unthreading the axle?
  12. #87
    Sep 2007
    Sorry, hiccup caused a double post.
  13. #88
    Not a bad idea, I'll see what I can find!
  14. #89
    ( ͡° ͜ʖ ͡°)
    Reputation: old_fuji's Avatar
    Mar 2009
    We had this at work one time, and we wound up jamming a cheap flathead screwdriver into the widest part of the hex bolt to unscrew it. Yeah, we had to replace the screw in the end, but the screw is screwed anyway.
    I lost my phone number. Can I have yours?
  15. #90
    Oct 2013
    THAT is NOT going to WORK!
    BANNED
  16. #91
    gazing from the shadows
    Jan 2003
    Quote Originally Posted by old_fuji View Post
    That. Or you can dremel a slot. Sometimes you can use an SAE/metric in a rounded out metric/SAE and get a tight enough fit to get it going.
    Making a slot then using an impact driver (if needed) is pretty much the way I end up dealing with most stripped fasteners. After trying other things first, which sometimes work. But they never work when I am under time constraints for some reason.
    BTW, looks like someone has NO IDEA what 10 Nm feels like.
  17. #92
    Today's nastiness:
    Obviously this could be a lot worse but this was off to a bad start. If you train indoors, or sweat a lot, or both...wash your bike regularly and change your damn bar tape more often than once every 3 years. It's not safe as corrosion can go unchecked for months if not years, and it smells like ass.
  18. #93
    May 2014
    Today's nastiness:
    I don't think I've ever had bar tape last 3 years. It usually deteriorates well before that.
  19. #94
    In all honesty it should be changed every 3-4 months.
  20. #95
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Depends on how little you ride. My first real roadbike, I passed on to family. It probably has only seen 20 miles of riding in the many years since, and done little more than sit on a garage floor ever since. Of course...the upside to black bar tape is it hides wear/staining....the downside is that you quit noticing how socked with sweat/salt the tape gets until you try to remove it.
  21. #96
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    Wise words. I usually notice how ridiculously overdue for a tape replacement I am when I'm about 5 miles into my ride.
    Then I forget.
    I have a box of fizik microtex (my long time favorite) tape waiting in my bike parts bin. It's been so long... it might have gotten permanent creases in it inside the box.
  22. #97
    May 2014
    Should months or miles be the factor? I have to admit I probably change mine about every 2 years. Never had a problem. I guess I'm not much of a hand sweater. My head certainly sweats as my skull cap and helmet are evidence of.
  23. #98
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Same here. In the hot humid summers though my gloves will be saturated in sweat where I can wring them out.
    I can easily get 2 years (10k mi) from bar tape.
  24. #99
    May 2014
    I ride about 3K miles per year and it is spread out on different bikes. The bike I ride the most gets about 2K miles per year.
  25. #100
    Apr 2006
    The worst part of the job is dealing with foul, old, putrid tape. And good old specialized clear gel pads underneath the tape, make me want to wear a Hazmat suit. Ugh!!!!!
    Sent from my SM-G950W using Tapatalk
  1. Is it a scam? check here for typical examples.
    By Coolhand in forum Classifieds Feedback - Scam Warnings
    Last Post: 07-16-2018, 08:43 AM
  2. 10 examples of brilliant shadow art
    By Henry Porter in forum The Lounge
    Last Post: 01-25-2011, 08:05 PM
  3. Replies: 126
    Last Post: 05-07-2009, 11:50 AM
  4. Some examples of short-reach handlebars?
    By dawgcatching in forum General Cycling Discussion
    Last Post: 07-23-2004, 12:15 PM
