Results 1 to 3 of 3
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    DA-9000 38 inner chainring
    So I have come into possession of a Dura-Ace 9000 38-tooth inner chainring. Just wondering if anybody uses a 38, and if they pair it with a 52 or a 53?
    I'm usually riding 53-39, also have 52-36 setup which I had used for a while... I'm wondering if the 38 would give me just a little more help for bailout gearing on steeps but would still pair well with the 53?
    Any thoughts?
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by jetdog9 View Post
    Any thoughts?
    Well, it's a little more - very little, only about 2.5%. Is that enough to matter to you? As for pairing with 53, the exact gearing sequence depends on your cassette. Plug it in a good gear chart and see. It's not gong to be a big difference. And the ratio between the two rings is closer than your 52-36, so if you can live with that you can live with this.
    If you were going to go out and buy it, I wouldn't bother. But since you have it, it's not much trouble to give it a try.
    Have you ever been to Electric Ladyland?
    Neophyte
    Jul 2007
    Hmm, well I see I have the wrong 52 for this ring and a 53 won't do at all... so I'll probably not use it. Thanks!
  1. Dura Ace WH-9000-C24-TU vs WH-9000-C24-TL
    By Philhumphrey in forum Wheels and Tires
    Last Post: 02-22-2014, 12:50 PM
  2. Smallest inner chainring
    By Inspector Gadget in forum Components, Wrenching
    Last Post: 09-29-2008, 02:07 PM
  3. 46T chainring- inner or outer?
    By steel515 in forum Components, Wrenching
    Last Post: 09-02-2007, 02:18 PM
  4. Silver compact 36T inner chainring
    By J24 in forum Campagnolo
    Last Post: 07-05-2007, 02:19 PM
  5. Shimano inner chainring
    By percy in forum Components, Wrenching
    Last Post: 02-02-2007, 04:26 PM
