Results 1 to 6 of 6
    Deda Newton 31.7 Handlebar / Thomson Stem
    I'm a beginner cyclist and was wondering if a Thomson 31.8 stem is compatible with a Deda Newton 31.7 handlebar? This is probably a stupid question, however, we beginners need to start somewhere. Thanks for the assistance in advance.
    srf
    srf is offline
    Jun 2004
    Quote Originally Posted by Paluchi
    It's a good question. Better than trying brute force when you don't know what'll happen. =) Zinn has a good writeup on this:
    http://www.velonews.com/tech/report/...es/8015.0.html
    Quote Originally Posted by srf
    Thanks, that was very helpful!
    Mar 2002
    That combo works great!
    Attached Thumbnails Attached Thumbnails Deda Newton 31.7 Handlebar / Thomson Stem-3377-ultimate-640.jpg
    Reputation: Nessism's Avatar
    The actual size is 1-1/4". When converted to metric units this works out to 31.75 mm. Some companies round this number down to 31.7 and others round up to 31.8 (which is technically correct since 5 rounds up).
    No worry.
    Reputation: merckx56's Avatar
    Aug 2004
    Yes, it works fine. I'm actually using the Thomson X4 MTB 31.8 stem with Newton 31.7 bars. Never slipped and the faceplate is a four bolt setup rather than the two bolt setup on the road version X2 stem.
    Pretty much here just to piss you off...
  1. Replies: 4
    Last Post: 08-17-2004, 07:32 PM
  2. stem rise & length
    By C-40 in forum General Cycling Discussion
    Last Post: 03-22-2004, 07:33 AM
  3. Thomson stem Qs...
    By Farmpunker in forum Components, Wrenching
    Last Post: 02-12-2004, 05:21 PM
