Results 1 to 25 of 31
    Velodramatic
    Reputation: chasingpixels's Avatar
    Jul 2007
    Deda Phazer handlebar Impressions and taping?
    Have any of you installed a Deda Phazer handlebar on one of your bikes? I've not been able to find any info beyond promo shots from the bike shows. Interested in your impressions and any info on how you taped the bars.
    I've seen one image (which I can't find now) that looks like the tape stops before the foam on the end of the drops and avoids the "Power Eggs" I'm not sure if this is the recommended method. It didn't look very good.
    Velodramatic
    Jul 2007
    That's what I thought
    It doesn't look like anyone's taken the plunge with the Phazer then. Not surprising perhaps given the different shape and heavy price.
    Anyone have any thoughts regarding Cinelli's Neo Morphe handlebars. I'm not too keen on Anatomic bars in general but it has some of the same specialized hand position thinking as the Phazer. If I remember correctly BikeSnobNYC loved it...
    http://bikesnobnyc.blogspot.com/2007...ds-barred.html
    thanks
    Team American Classic
    Reputation: The Flash's Avatar
    May 2002
    Quote Originally Posted by chasingpixels
    thanks
    I have the 3T version of this bar. Works really well and has a number of comfortable positions. My only issue with it is that it did not come in a 46cm C-T-C measurement.
    Dec 2004
    I got a picture for you.
    Sorry I do not have instructions but I have a picture that you can follow.
    Attached Thumbnails Attached Thumbnails Deda Phazer handlebar Impressions and taping?-bici%5B1%5D.jpg
    May 2002
    Quote Originally Posted by Spezzoto
    Any problems with getting the SRAM Red to fit securely on the bar? Did the provided hardware fit the Red shifters? I'm looking to buy one today if SRAM Red fits on it fine....
    Dec 2004
    No problem with RED
    Quote Originally Posted by The Flash
    No problem at all. No hardware required. Where did you got the handlebar from?
    May 2002
    I work for a bike shop so they ordered it for me, so I am not sure where it is coming from. How was the cabling? Is there any internal routing or is it standard? Would hate to have to cover up to much of the top of that bar!
    Thanks!
    Flash
    Nov 2006
    The latest Velonews had a review of them. They weren't crazy about the bar or the way you mount the shifters.
    May 2002
    I read that review, but they said the issue was more related to Shimano shifters. I am using the SRAM Red's and from the pictures I've seen with the Campy shifters, they look pretty flat. The bolt on the SRAM's is also lower than the one on the Campy's, so I should be able to get the position I want.
    Hopefully this will end my quest to find a comfortable bar.....
    Velodramatic
    Jul 2007
    Looks quite nice
    Thanks for the image Spezzoto. First off, the bars look good on the bike. Neither the power eggs or the bulge on the bottom of the drops look too obvious. It still presents a nice classic round appearance in profile.
    I'm having trouble following the thread so a couple of questions guys.
    Flash
    Q. From your first comment you were referring to the 3T version of the Cinelli Neo Morphe bar, right? From your later comments it sounds like you've ordered the Deda Phazer too. Are you replacing the 3T bar on your bike then?
    Spezzoto
    Q. Is this your bike? If so, do you have any more images from other angles? Does the taping stop between the hoods and the eggs? I can't tell if there's tape inside the egg position towards the stem.
    It's interesting that the titanium bike these appear on are quite similar to the Enigma Eulogy I was considering them for. It also has a carbon rear triangle.
    thanks everyone.
    May 2002
    I tend to switch between the 3T Biomorphes and some Ritchey WCS Classics and the Oval Concepts RAero 900. Love the wing on the OC's, but can't reach the brakes in the drops. Love the drops on the Ritchey's and I can reach the brakes, but the tops have too much reach. The 3T's are a compromise of the other two, but doesn not excel in any place and the drops aren't that comfortable.
    Been waiting for the Phazer's for a year. I hope they live up to my expectations....
    Flash
    Flash
    Spezzoto
    thanks everyone.
    Velodramatic
    Jul 2007
    Starting Rotation
    Flash,
    You must be going through a fair bit of handlebar tape with that starting rotation of bars. Post your reactions and some images please when you've installed the Phazer. What bike model are you putting them on?
    Re: your comment that you can't reach the brakes in the drops with the Oval Concept bar. I gather the SRAM Red's lever adjustment can't bring them close enough. After hearing that the next Dura Ace lever will have a similar adjustment, I'm hoping Campy will come through eventually with adjustable-reach Ergo levers.
    thanks
    May 2002
    Will do....I should have them here this week. The worse think is that I was using white bar tape and having to replace that once a month(I buy in bulk!). The SRAM Red adjustment is great for normal hands, but mine are a bit short. On a bar with a classic curve(non-anatomic), the Reds work great and are easy to reach making it quite comfortable to ride there. The OC RAero bar makes it almost impossible to reach without twisting my wrist outwards. The 3T is a pretty short reach to the levers as well, it just needs more of a drop.
    Unfortunately for Shimano, the Reds shift waaaaaaayyyyy too good for me to switch back....
    May 2002
    Got the Phazer and did a 40 mile ride with them. They are comfortable, but there are a few nagging things I need to figure out. I prefer to keep the drops flat and level, but the SRAM Red shifters are too far down and I can't move them higher without drilling the bar out. Both sets of bolts are too long for the Reds, so I had to grind down the Campy set as it was bottoming out in the nut. Now I can get them tight, but the angle still isn't that good. The bolts only seem to fit in one way, so you are stuck with the angle of the shifters which is almost straight, but seems to canted outwards a it.
    I'll snap some photos when my daughter brings my digital camera back tomorrow....
    Velodramatic
    Jul 2007
    Look forward to the pics
    Glad the bars arrived and you got out with them. The pictures will make things more clear I'm sure. One question, which may be silly... I know they got a novel attachment method with the pass-thru-bolts you mention, but is it not possible to install the levers in a conventional way around the bar?
    Or does the shape of the bar preclude regular clamping?
    May 2002
    Clamp won't slide on, but if you pulled it apart, it would probably work as long as it does not crush the bar in the molded cut-out area. I will give it a shot here shortly and let you know....
    Velodramatic
    Jul 2007
    Of course, I forgot for a moment about the expanded region at the end of the drops, you can't slide it on. Don't take any risks with your new bar on my account.
    Velodramatic
    Jul 2007
    Any photos yet
    Flash,
    Have you had a chance to photograph the bars. Anxious to see how you taped them and how they look in profile, 3/4 front etc.
    When you get round to it.
    thanks
    May 2002
    Going to try and post these up....
    Attached Thumbnails Attached Thumbnails Deda Phazer handlebar Impressions and taping?-daddys_bike_862.jpg   Deda Phazer handlebar Impressions and taping?-daddys_bike_863.jpg
    Velodramatic
    Jul 2007
    Thanks Flash for posting the photos, they really help.
    I like the shape a lot.
    From your earlier post, I think I see what you meant... the drops are not quite parallel with the ground, but I don't think you're giving up much to achieve the flat, top platform at the hoods. The nice bulge at the end of the drops should make it almost impossible for your hands to slip off anyway.
    Did you get out this weekend for another ride with them?
    I'm going to order the gloss carbon version (no bar code) and experiment with additional tape inside the power eggs running towards the stem.
    I've still got another month to wait before my Enigma Eulogy frame arrives. I blogged about all the other components in the build, and will have an interesting account (I hope) of how it all comes together later. Eventually I'll add a couple of images to this thread, so anyone else thinking of buying the Phazer will have more to go on.
    May 2002
    I've got about 200 miles on them now and they are definitely keepers! I've gotten alot of complements on them and they work really well. I am still deciding if I will rotate them up just a bit or keep them where they are. I've always been used to the top almost having a slight angle up on the shifter and these are completely flat. Where it is now are the best drops I have ever used! Very comfortable and the drop is just right. I have wide, short hands and these fit perfectly and I can still reach my brake levers with ease.
    The Power Egg area is very nice and you almost don't want to move off of it back onto the shifters. My only gripe on the whole bar is that it actually has the word "Power Egg" on the top of mine which is a little dorky. Even without taping over it, the whole area fits the hand very well with no numbness.
    I'd highly recommend it!
    Velodramatic
    Jul 2007
    More great feedback. Mine's on the way.
    Reputation: tindrum's Avatar
    Mar 2008
    whats that black and white stitched bar tape? really neat.
    Velodramatic
    Jul 2007
    Additional Phazer Images
    Here are more images of my Phazer bar (clear coat carbon version) as promised. It's a beautiful piece of carbon.
    Jan 2009
    Deda Phazer Bar
    Where did you order your bars from? My local bike store cannot get there hands on them yet.
