Results 1 to 9 of 9
    jta
    jta is offline
    Jun 2012
    Determining chain length on a chain that's already installed
    Sorry, I'm sure this topic's been covered before:
    I just took delivery of a new bike with an Ultegra 8000 drive train. It came with 52/36 and 11/32 gearing and I immediately swapped it out for 50/34 and 11/28.
    Should I shorten the chain?
    I am familiar with Shimano's dealer manual and their method of determining chain length for cassettes that have cogs with 28T or more, but it doesn't seem to help with a pre-installed chain.
    Oct 2009
    Parks Tool has a good video section that covers this(chain sizing), among others, also will you by chance be putting the 11/32 back on at any time.
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    Shift small, small. Is the chain slack? If so, its too long.
    Go to the big ring, slowly shift down the cassette from the small cog. Watch the rear derailuer, does it go tight? The cage should not be rotated much forward of vertical. If it can get into all ranges, its good.
    jta
    jta is offline
    Jun 2012
    Quote Originally Posted by Ventura Roubaix View Post
    thanks, good advice - I actually referred to that video awhile back and forgot about it.
    No chance the 11/32 is going back on. My other bike is set up with a 12/25 and I rarely use the 25T cog.
    jta
    jta is offline
    Jun 2012
    Quote Originally Posted by tihsepa View Post
    Thanks, between the PT video and this, I think I'll be able to figure it out. The small/small method is what I'm familiar with, but Shimano has different instructions for 28T and above.
    jta
    jta is offline
    Jun 2012
    Okay, tried the small/small technique then switched to the big ring and went through the range. The chain seems to be okay as is for now.
    A bit surprised, but then I only lost 2 teeth in the small/small combination and in the big/big, the chain is pretty taut, so it must have been nice and snug with the bigger rings.
    jta
    jta is offline
    Jun 2012
    Update: Went ahead and took two inks out. I have an extra 12-25 cassette sitting around. I should be able to go back and forth from 11-28 to 12-25with out worrying about chain length now.
    BTW, shifting on Shimano's new groupsets (DA9100 and Ultegra 8000) seems to be an improvement over previous - the short throw on the front lever makes shifting onto the big ring effortless.
    Thanks for the advice everyone.
    Feb 2002
    Quote Originally Posted by jta View Post
    Why? If the chain wasn't hanging slack in the small-small combination, there was absolutely no reason to remove links. Things do not work better with a shorter chain.
    jta
    jta is offline
    Jun 2012
    I am admittedly not the expert here - just trying to follow the guidance of Park Tools and others that know more than me.
    As I mentioned I wanted to be able to swap out to a smaller cassette in the future and not worry about it. Figured this was a way to cover both options.
  1. Replies: 8
    Last Post: 03-21-2014, 10:04 AM
  2. Help Determining Spoke Length
    By digita6 in forum Wheels and Tires
    Last Post: 08-21-2013, 10:40 AM
  3. Determining spindle length
    By shudson16 in forum Components, Wrenching
    Last Post: 02-23-2011, 01:49 PM
  4. Determining fixed gear chain length
    By limzjun2002 in forum Fixed/Single Speed
    Last Post: 07-26-2006, 12:49 PM
  5. determining ideal cockpit length
    By ink1373 in forum General Cycling Discussion
    Last Post: 01-18-2006, 02:48 PM
