Results 1 to 20 of 20
Thread: Di2 pulleys
    Oct 2013
    Di2 pulleys
    My bottom pulley is getting pretty wobbly and today it was squeaking.
    I got a orginal Di2 Ultegra groupo. Are the pulley sets the same with a mech RD?
    I found a Shimano Ultegra 6700-A 10 spd kit online, will that work?
    I been to several shops on my other mech set and never had much luck finding any pulley kits at any LBS I went too! I guess I am pretty hard on those pulleys.
    BANNED
    Reputation: velodog's Avatar
    Sep 2007
    Why not just clean and lube them until you get replacements?
    Too old to ride plastic
    Sep 2007
    Here's the EV of the Rd-6770 http://si.shimano.com/pdfs/ev/EV-RD-6770-A-4116.pdf
    It looks like you could use the pulleys from a 6870 RD if you can find that.
    Oct 2013
    Thanks, but your comments do not respond to my question. I have a Di2 groupo.
    BANNED
    Sep 2007
    Actually, they do. The 6770 that I referenced is the original Ultegra DI2 RD that you indicated you had. If you look at the EV that I posted a link for, it shows that the 6870 RD, the 11sp Ultegra DI2 RD, uses pulleys that are compatible with the 6770 that you indicated you have.
    'brifter' is a lame word.
    Wait...what...?
    I work for some bike racers
    and a bunch of skateboards
    Forever a Student
    Mar 2014
    Wait...what...?
    Di2 pulleys are magic.
    use a torque wrench
    He must have the Di2 brakes as well...
    Forever a Student
    Mar 2014
    count on it.
    Di2 crankset too.
    use a torque wrench
    Oct 2013
    Well, that diagram does not look anything like my RD. Mine has a rear structure that kinda looks like a can from the rear. I think they made a design change. The diagram doesn't indicate whether it is 10 or 11 speed that I can see.
    I don't know what the product number is, where can u find this?
    When I google pulley kits, it comes up with a different kit for 8,9, 10, & 11 speeds, so I don't see how a 11 speed pulley is the same as my 10 speed. I'm not saying it won't work, but if I'm ordering something it may as well be the correct part.
    I went to shimano web site, it is a mess, I do a search in the archives for 2012 Di2 and the tech pdf doesn't even list it.
    What I need is a diag for my RD & a diag for a mech RD, 2012 indicating they are the same product number. Or someone that has a pulley kit for a 2012 Di2 Ultegra.
    BANNED
    Jesus...they're both 10 speed. They're both 67xx derailleurs. In the tech docs there are different part #'s, the Di2 derailleur uses the ceramic bushings, the mechanical does not. That's the only difference. They both use the same 12.5mm/10.5mm axle bolts. I am quite sure they're interchangeable. The Shimano part # for the 6770 pulleys is:
    Y5X998080
    Forever a Student
    Mar 2014
    use a torque wrench
    Oct 2013
    Why do you keep posting 11 spd stuff?
    BANNED
    Forever a Student
    Mar 2014
    Because I'm a professional bike mechanic, and that's what I do.
    I'm going to tell you to use an 11 speed chain as well. Woah, calm down now. I know... really I do... that 10 and 11 are different numbers.
    But maybe, just maybe...
    use a torque wrench
    Sep 2007
    This thread should be merged with the marijuana thread.
    now that it's mostly legal does anyone burn......
    Oct 2013
    You are a professional BM. In shimano's own literature it states not to use 11 spd pulleys with 10 spd. I'm not a professional BM, so I'm going with what the manufacturer states.
    I previously stated I wanted the exact right component, if I wanted to use any old thing, I could have got something out of my spare parts bin & wouldn't be here.
    BANNED
    It's funny how so many people don't understand the idea of a 3/32" chain and how it works. 11 speed chains work fine on 10 speed cogs. Wonder why that is?
    Sep 2007
    Shimano's own literature, in the form of the link to the RD-6770 EV that I posted in my initial reply to you, show the pulleys from the RD-6770 (10sp DI2 RD) as compatible with those from the RD-6870 (11sp DI2 RD) - go figure.
    Oct 2013
    Yea, it is all very simple. And the product compatiblilty possiblilties are clearly obvious.
    Anyway I got what I need, have a great day!
    BANNED
    Oct 2013
    I got my pulleys, I removed the bottom one, somehow the bearing was in off axis with the outer pulley. Don't know quite how that would happen, but I just put a new one in.
    BANNED
  1. 11t or 10t pulleys
    By lawrence in forum Components, Wrenching
    Last Post: 06-21-2009, 04:54 PM
  2. 11t vs 10t pulleys?
    By crestlinefarm in forum Components, Wrenching
    Last Post: 06-10-2009, 03:35 PM
  3. Pulleys - anyone?
    By Rev. Christensen in forum General Cycling Discussion
    Last Post: 07-31-2008, 06:28 AM
  4. Dr Pulleys
    By tgiboney in forum Components, Wrenching
    Last Post: 12-21-2006, 07:00 PM
  5. I need Ultegra pulleys...
    By AlanS in forum Components, Wrenching
    Last Post: 07-17-2006, 09:10 AM
