Results 1 to 6 of 6
    Sep 2004
    Difference between mountain seatpost and road seatpost
    I was thinking of buying an Oval concepts road seatpost, but they also have a mountain bike seatpost with the same diameter but a different length for much cheaper price. Is there any difference between the two other than weight?
    Jan 2009
    You've heard the expression "dumb as a post". Seatposts don't know or care where they're used, road, MTB, fixed wheel, it's all the same.
    What counts is the diameter and length. There are sometimes other differences in posts made for road vs MTD, such as rear offset, and in some cases MTB posts are built stronger (heavier) in expectation of lots of pounding in use.
    If you're willing to accept the weight penalty of the less expensive MTB post, go for it, and spend the savings on something worthwhile.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Reputation: JCavilia's Avatar
    Sep 2005
    One caveat: Make sure it won't be too long. Sometimes on a relatively small road frame a very long post will bump into the bottle-cage bolts before you can get the seat low enough. Depends on your frame and your fit. Of course, you can cut off the excess if you're handy with the hacksaw and file, which would take care of the weight penalty, too.
    Roadie with unshaven legs
    Dec 2005
    Quote Originally Posted by JCavilia
    The solution: hacksaw!
    I used to buy mountain bike versions of nicer seatposts because they're longer but are otherwise the same. By doing this I can cut off the marred lower portion of the post and end up with an essentially new road seatpost. Just make sure that you don't cut it too short as a really short post will have almost no resale value down the road. About 10-11" overall length is about right.
    Banned forever.....or not
    Aug 2002
    I got a nice Easton MTN post for $35, but was too lazy to cut it off.
    Those extra 30g are killin' me.
    Dogbert.
    I>U
    n00bsauce
    Reputation: Mel Erickson's Avatar
    The difference between a mountain seatpost and a road seatpost is about the same as the difference between a mountain chain and a road chain.
    "Those who can make you believe absurdities can make you commit atrocities." Voltaire
    There are your fog people & your sun people, he said. I said I wasn't sure which kind I was. He nodded. Fog'll do that to you, he said.
    "We are all ignorant about most things."
    Mel Erickson
Sea Otter Classic
Contest
