Results 1 to 16 of 16
    a real member's member
    Jul 2016
    Question do you wrap bars differently for barcons?
    i have never built up a bike with bar end shifters. every time i've bought a bike with barcons, i have always parted them out to offset the cost of the flip. (they're always easy to sell for $40.) but i'm rebuilding a vintage follis for a friend with suntour barcons. he wants to use cotton tape.
    the way i usually wrap:
    1. start at the bar end.
    2. wrap inside-out.
    3. do a figure 8 around the lever.*
    4. finish at the top with 10mm wide electrical tape or embroidery thread.
    * except with cotton tape, i don't do a figure 8. it's too thin and folds on itself. instead, i use the little piece of extra cloth tape to hide the brake lever clamp.
    Nov 2002
    I don't do anything different except that I don't push the tape in the end of the bar; no room for it. Maybe room for you as cotton tape is thin.
    Oh yeah, I run the shifter cables all the way under the tape. Shifts great with modern lined shifter cables. Much cleaner and the cables don't get in the way. I bought some bulk SP41 housing and used a tandem shifter cable (not sure I needed that for the extra length or not). Used SP41 grease to lube the cables.
    'brifter' is a lame word.
    Quote Originally Posted by blackfrancois View Post
    2. wrap inside-out.
    That works for me
    I work for some bike racers
    and a bunch of skateboards
    Jul 2016
    thanks for the replies.
    do you have a pic of that?
    and do you run into any problems with loose tape at the bar end (because the barcons prevent the tape inside the bar end)?
    Jul 2016
    here's the bike.
    Nov 2002
    I haven't had the tape come loose. I wrap it really tight to start and use a piece of electrical tape to the bar at the end of tape for good measure.
    Reputation: velodog's Avatar
    Sep 2007
    I've been able to tuck bar tape into the end of the bars while using bar end shifters. It's a bit tight and you have to be careful with the amount of tape that gets tucked in but with cotton tape it shouldn't be to hard.
    I also run the cable all the way under the tape, much neater. Also, have you tried, with exposed brake cables, to secure the brake cable bands to the bars with electrical tape before taping the bars? You can then tape over the clamps and then mount the brake levers, on top of the handlebar tape, to the clamps. Very clean appearance with no gaps or bulges where the tape would other wise be getting wrapped over the brake levers and under the hoods.
    Too old to ride plastic
    Jul 2016
    can you clarify this? i don't know what you mean by "bands." the follis will get non-aero levers. and thanks for the reply.
    Jul 2016
    you're talking brake housing, right?
    would derailleur housing work better or worse when running it under the length of the tape from barcons? i would just assume brake housing would flex more and allow smoother shifting with these suntour friction shifters.
    Nov 2002
    I'm using shifter cable housing. 10 speed indexed. Shifts great.
    Sent from my iPhone using Tapatalk Pro
    Sep 2007
    The clamping bands.
    Mount the brake levers, secure the banded clamps to the bars with tape or sum such and remove the levers leaving only the clamping bands. Wrap the bars leaving nothing but the nutted portion of the clamp exposed and replace the levers on top of the tape and tighten down.
    From Velo Orange
    Wrapping Non-Aero Brake Levers
    The clamp and body of non-aero brake levers are much smaller than their aero counterparts. Being able to see the clamp through your new bar tape is unsightly and detracts from the appearance. When you've set up the position of the levers, put some scotch tape on the clamp to hold it in place. Unscrew the body from the clamp. The clamp should stay in place by the tape. Wrap around the clamp and screw the body back on. Voila! No embarrassing clamp is visible through your wrap.
    Jul 2016
    ^ thanks. ok, i see what you're saying now. i tried that once before on a bike. i can't remember the particulars, but i never did it again. maybe, though, it would help me when i use cotton tape for a customer. i never use cotton tape, myself, so my experience with it is limited.
    thanks. that detail helps.
    @velodog, do you also use derailleur housing when taping barcon cable the length of the bars?
    Sep 2007
    yes, modern shift cables.
    Jul 2016
    that was a first for me. it was fun.
    Looks good!
    Jul 2016
    thanks!
  1. Another wrap...anyone ever just wrap over the old bar tape?
    By Erion929 in forum Beginner's Corner
    Last Post: 08-02-2010, 09:58 PM
  2. Bars and Barcons
    By Deering in forum Components, Wrenching
    Last Post: 06-11-2007, 11:05 AM
  3. Barcons and XT rapid rise rear derailleur
    By gotbones in forum Cyclocross
    Last Post: 07-21-2004, 12:01 PM
  4. newbie help please!: How to remove barcons?
    By jpo245 in forum Components, Wrenching
    Last Post: 05-07-2004, 08:37 AM
  5. dura ace barcons & 04 xtr rear derailer ?
    By raceline in forum Cyclocross
    Last Post: 04-30-2004, 02:11 PM
