Results 1 to 3 of 3
    Apr 2013
    Dura Ace 2013 DI2 problem
    Installed Dura Ace 2013 DI2 on a Cervelo S5 and connected all the cables to the different components (shifers, upper and lower junction box and both derailleurs). The system is dead. No light, no beep, no movement. Trying to find the problem i checked:
    - all cables and connections
    - battery voltage 7.6V as it should be
    - fully charged the battery again
    None of the above helped! Really makes you wanna go electronic...NOT!
    Sep 2007
    Do you or your shop have access to the PCE-1 diagnostic tool? With that you can plug each component into it and it will find the problem.
    Sep 2007
    It might need a firmware update. Mine needed an update from new as nothing would work. I think it was the battery junction that wasn't running the latest firmware on mine.
    Trailflix - Now with forums and on Facebook.
    My bikes
  1. Dura Ace 2013 DI2 problem
    By bikeoholic in forum Bikes, Frames and Forks
    Last Post: 04-13-2013, 02:25 AM
  2. Tour de France 2013 and environmental problem
    By MatthieuS in forum Pro Cycling - Tour de France
    Last Post: 11-28-2012, 04:41 AM
  3. 2013 CAAD10-1 Won't Have Dura Ace
    By terbennett in forum Cannondale
    Last Post: 10-08-2012, 02:54 AM
  4. Dura Ace Hub / Freewheel Problem
    By manthei2 in forum Components, Wrenching
    Last Post: 06-21-2010, 12:06 PM
  5. dura ace 9spd. rd. problem
    By slowtrevor in forum Components, Wrenching
    Last Post: 07-13-2007, 07:02 AM
EUROBIKE
