Results 1 to 5 of 5
    MWT
    MWT is offline
    Nov 2002
    Dura Ace 7850-SL wheel freehub body removal
    Shimano sent me a warranty replace freehub body for my Dura Ace 7850-SL wheels. These particular freehubs have a problem with an occasional load "clunking" sound when they engage. Apparently, Shimano acknowledges the problem and sends replacement freehub bodies direct to consumers.
    Anyway, how do I install them? Thanks in advance for any tips.
    PSC
    PSC is offline
    Mar 2004
    Shimano's website has a tech section:
    http://techdocs.shimano.com/media/te...9830616109.pdf
    Jul 2011
    i have a problem with my rear wheel, while spinning it slows down quicker than normal, i have loosened the cones and regreased, but still same problems, any ideas?
    Jan 2009
    Quote Originally Posted by opollo creed View Post
    The rate at which a wheel slows down doesn't mean much. Lighter wheels, or lighter tires on wheels mean less inertia. Couple that with a little bit of seal drag, (worst on new wheels until seals wear in a bit) and you have some very high quality wheels, that won't spin half as long as the cup/cone wheels on a clunker.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Nov 2005
    I am way late to this party, but you might check that the washer between freehub and hub is in place. I have the same wheelset and found this washer missing. My first ride was very dissappointing as my chain sagged severely while freewheeling. LBS put in the washer and all was great after that.
  1. Dura Ace 7850-SL freehub
    By MWT in forum Components, Wrenching
    Last Post: 07-21-2011, 09:21 PM
  2. Pre 97' Dura Ace freehub body
    By jjcoffman in forum Components, Wrenching
    Last Post: 03-08-2011, 04:07 PM
  3. Dura Ace 7700 Freehub body removal
    By kam in forum Components, Wrenching
    Last Post: 06-30-2006, 03:24 PM
  4. Freehub body removal, necessity is the mother of invention
    By handsomerob in forum Components, Wrenching
    Last Post: 06-06-2006, 12:44 PM
  5. Dura Ace freehub body to Ultegra
    By turbomatic73 in forum Components, Wrenching
    Last Post: 02-15-2004, 02:52 PM
