Results 1 to 6 of 6
    May 2008
    Dura Ace 7900 Brake Caliper - Rear Pivot Bolt too small?
    I am installing the rear 7900 brake calipers on my 2006 Lemond Tete de Course and I think the rear pivot bolt used to install the caliper onto the frame is too short. The front caliper went in perfectly but the rear one is not. According to Shimano's website, the rear caliper's bolt is 1.5" but there is no way that is going to be long enough. It is #4 in the attached diagram link.
    http://techdocs.shimano.com/media/te...9830651588.pdf
    Am I doing something wrong? Are there different lengths available and I need to order a longer pivot bolt?
    wim
    wim is offline
    Feb 2005
    Just use a longer pivot bolt nut. Get one (any LBS) long enough so it engages at least six pivot bolt threads when it's tight. If you want a genuine DA 7900 nut, get one of the nuts listed for the front brake.
    /w
    Jul 2006
    Sorry Wim but a longer nut will not magically make more threads engage it. Longer nuts only prevent the bolt from bottoming out in case the bolt is too long.
    Quote Originally Posted by swifty
    You're confused. A longer nut is indeed the solution to a frame with a thicker than normal brake mounting area. It's not often a problem with the rear brake, but frequently an issue at the front. Most forks come with an appropriately long nut, to mate with the standard length mounting stud.
    A brake mounting stud would never be 1.5 inches long. Perhaps 1.5cm.
    duh...
    Jan 2005
    that was true in the days of non-recessed nuts, but those days are long over...
    Quote Originally Posted by mikagsd
    Fat tire Fred....you are the bike god of the universe and unless someone agrees with your reasoning they are just plain stupid
    Jul 2006
    Oops, I apologise for the brain fart. You are right of course.
