Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
  1. #26
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    Quote Originally Posted by crewdoglm View Post
    Copy all thanks. Suggest with empathy and respect and instead of snarky condescension and these conversations will go better. Merry Christmas.
    Where you being empathic and respectful when you said:
    "These are the critical facts LOL."
    "I read the same F&%$ing chart dude"
    "Yes... those are the basics... Check"
    " none your patronize-the-novice trouble-shooting applies because, shocker, I'm actually experienced with **** as you are."
    I keep being surprised how sensitive the snarkiest, rudest people are to the smallest perceived slight.
  2. #27
    Jan 2014
    Quote Originally Posted by steelbikerider View Post
    Make sure that the tab on the washer under the cable attachment bolt is correctly aligned before tightening the cable bolt. Also be sure that the shift lever is shifted to the proper spot before installing the cable. (been there, done that on both)
    Thanks. Turns out your suggestion was the one that did the trick. That cable bolt washer has basically an L-bracket on it which must be oriented aft-wise or else it affects the derailleur movement. That's not a quirk I've seen before and the 7900 doesn't behave that way. Thanks.
  3. #28
    Jan 2014
    Addendum: As I indicated, I am willing to be wrong and I did in fact get it to work. Just throwing that out in the interest of fair play.
  1. Dura-ace 7900 Shifters and M773 Derailleur
    By fpkeegan in forum Components, Wrenching
    Last Post: 02-21-2011, 01:35 PM
  2. Dura Ace 7900 Front Deraillure with 7800 shifters
    By cliff in forum Components, Wrenching
    Last Post: 09-28-2010, 04:34 PM
  3. Replies: 5
    Last Post: 07-10-2010, 12:17 PM
  4. Will 7900 STI levers work with 7800 rear derailleur?
    By yzfrr11 in forum Components, Wrenching
    Last Post: 06-05-2010, 01:40 AM
  5. 7900 Rear Deraileur with 7800 shifters?
    By ReedJay in forum Shimano
    Last Post: 04-02-2009, 02:27 PM
