I've been looking at new cables, and have found Blue Sky have the new DA9000 brake cables down to $20, but cannot find the 9000 shifter cables (which apparently have much less friction than DA7900).
Are they out? I read they retain the SP-41 outer, but have a new super slippery inner. I can't see them listed anywhere.
i've always liked the SRAM pitstop cables, they seem to be a little smoother than Shimano. i'm sure they'd work just fine. the difference between the 'smoothest' and the 'least smooth' cable is pretty minor. remember...they're just cables. you don't have to use the 9000 cables. not even Shimano would design a shifter that had it's own specific cable, and would not work w/ anything else.
2012 Trek Cronus Ultimate w/ SRAM Red Black
2010 Cervelo T1 sprint bike
2011 Cervelo P2 pursuit bike
FMF 24" cruiser
Bianchi Pista road fixed gear
1949 Columbia 26" cruiser w/ SRM & fenders...and rust
'05 Suzuki DRZ400SM
Had a chance to see and feel the new 9000 cables at a demo two weeks ago. They are very slippery. Shimano says it was required to reduce friction of the extra bends created with the new under bar shifter cable routing.
I too am sure other cable will work but they sure were slippery. They also said the coating will stay on the cable unlike the aftermarket coated cables. Guess time will tell. I did see where the coating was rubbing at the rear derailleur barrel and the cable was still very slippery there. At first glance it seems to be good stuff.
Thanks, I'd like to give the 9000's a go though. The brake ones are down from $45 to $20 at BlueSky, so matching gear cables should be about $45 at full price. I'm interested because Shimano went PTFE coated to improve shifting with 7900 under bar routing, but found the PTFE came off. So this is their considered and improved solution ... should be good stuff.
I'll probably order some from BlueSky (shame the shipping is $8 and I have to pay tax too ... ) and look out for the shifter cables. Seems odd that they're 'needed' to get the most from DA-9000, yet you can't buy them (I literally cannot find them listed anywhere). I can find the DA-7900, but they're the ones reported to have issues (over medium/long term?) with PTFE balling up.
the coating on the inner wire is similar to the gore coating. assuming cervelo used the shimano cables. the sharp bend as the cable exits the RD frays to coating too.
I'm curious if blue sky actually has them in stock or if they are listed but for preorder. I have read some threads about them listing items out of stock and not letting customers know the item is on back order until the customer asks why they haven't received the item.
Thanks for the info on BlueSky being ... well, not exactly Jenson/Competitive/CRC in terms of upfront advertising of stock levels. I'll look to order from bluesky anyway (frustrating that it's $20 + $9 shipping + $2 tax ... I was going to get two sets to cut the cost down, but still works out to a big percentage as shipping). These cable's aren't holding up a build, just going into the spares bin ready for the next strip and rebuild of the bike.
My 'go to' cables (I only seem to work on Shimano systems these days, working on my bikes and half a dozen friends bikes) are Dura-ace 7700/7800 kits. I have picked up a cheap goodridge kit, but not fitted yet. Gore look interesting, SRAM too, but I've found myself going to Shimano for more and more things these days.
If the new DA-9000 cables can be had on special (say $30 a set delivered ...), then they'll likely become my new go to cables (which assumes the performance/life is as made out in the release articles). I know the 'go to' question wasn't directed at me.
So when you're wrenching on a bike with 7900 shifters and the end user wants the optimal results what is your 'go to' cable? the SRAM Pitstop?
not sure when the 'end user' would not want optimal results, but yes...we use SRAM Pitstop shift cables for everything except Campy.
FMF 24" cruiser
'05 Suzuki DRZ400SM
Well there are those among us that claim some sort of conspiracy where the LBS has it in for the consumer. It's some bigger plan.
Kidding aside; my wording for that question was weak and lacking. A shop near my house will pull cables from a huge bundle of bulk cables on a 'routine' job. I think they are Jagwire, decent cables. Then if the customer wants to pay a premium the techs will cable a Shimano equipped bike using the individually carded, Shimano Dura Ace shift cables.
That was my question, "what is your premium go to cable"?
And I got my answer, thanks.
ahhh, the old 'shop mechanic conspiracy'...a lot of times there is something to that.
we used to sell the D/A 'kit' every now and then, and also the individual D/A cables, but it was pretty rare that a customer would want to pay the premium. we do stock Campy cable/housing sets as well as single Campy brake and shifter cables. for whatever reason, most Campy customers seem to want their bikes done w/ the full kit.
i think i've probably influenced a number of our customers and convinced them that if they're riding a lot they need to replace their cable/housing on a regular basis. they usually ask "what do you use?", and my reply is to show them the SRAM cables/housing on my bike. once they feel how smooth it shifts and know that it's reasonably priced, they are fine w/ it. because i've been a team mechanic for so long, i've come to view cables/housing as something that should be replaced fairly often to maintain optimal shifting performance. it's cheap, and it's easy. i'm also a fan of keeping my bar tape fresh so it doesn't smell like ass, so i do both every few months.
i've tried the D/A cables, i've used Gore, Nokon, Yokozuna, Jagwire...you name it. no one in particular is really any better than the rest. the Pitstop cables are 1.1mm instead of the Shimano 1.2, and they're also a little bit smoother. they've always worked well for me, so i will continue using them. i do use the newer Gore liners on my bikes, just to keep them smooth through the bb cable guide and to keep the dirt/moisture out of the housing. they're super easy to install, lemme know if you want a photo.
i don't lubricate the new cables/housing either. i probably could since i use the liners, but i've got into the habit of not doing it.
FMF 24" cruiser
'05 Suzuki DRZ400SM
As a small bike shop owner with over 30 years wrenching experience it always astounds me that most cyclists cheap out when it comes to cables, housing, & ferrules/endcaps. The quality & installation of these hardworking components make such a difference regarding shift & brake performance; and the cost to upgrade to stainless cables, Yokozuna/Ripcord housing, and brass/aluminum ferrules is usually less than $15. There is no "shop mechanic conspiracy" and the shop is doing the customer a disservice if it doesn't advise the customer to pay the few extra bucks (Now, of course, we're talking about better quality bikes that are ridden a bunch).
If you use good stuff, install it properly, inspect it regularly, and keep your bike clean you don't need to replace it very often at all.
cxwrench, a couple things - the Pitstop cables come in 1.2mm & 1.1mm diameters and it's best to use Campy specific derailleur cables because the ends are a bit smaller.
I work for some bike racers too...
'79 Lugged Columbus SL with full vintage Campy Super Record & Cinelli
'96 American Classic ti with 9-speed Campy & eclectic build (Very light)
'10 Van Dessel WTF, currently set up as a gravel fondo bike
'12 Bianchi Vigorelli w/Infinito full carbon fork,Campy Record 11 & matching Brooks kit
'12 Bianchi San Jose SS 'cross
'12 Handsome "Shop Bike" light-weight coaster brake speedster
'10 Ellsworth Moment 69'er (And very light too)
'88 American Breezer mtb
'90 Team Fat Chance mtb
'86 Crotch Rocket mtb
yeah, i know about the Tefzel coated 1.2mm cables and i don't like them too much. i've never seen a coated cable that didn't become at least partially uncoated real quick.
if you're talking about Campy needing Campy specific cables, yes...good advice. you have to use Campy(compatible) cables for both brake and shift when you're working w/ Campy shifters.
i'll never back off from recommending cable/housing replacement at fairly regular intervals. keeping them clean is only part of the deal. they do fray as you know, and w/ the newer shifters that all have under-the-bar-tape shift housing it's not possible to inspect the cable as you could before w/ Shimano. i'd rather keep my bikes shifting perfectly and not have to worry about a tired cable breaking when i'm 30mi from home. it's too cheap and easy to leave them on the bike for more than 6-9mos for me, and i don't put more than 4-5000mi a year on any bike.
FMF 24" cruiser
'05 Suzuki DRZ400SM
Now who doesn't like a photo?
Among the (20) or (30) pics I know you're willing to post could ya include one of the cable routing guide under the shell?
I think I know what you're describing. Sounds like you're running about 3 or 4 in. of housing liner thru that cable router.
here are the liners i have now, they're the older style w/ the ferrule included. the new liners just have a little black plastic flange thing on the end and you run the liner through a Gore ferrule.
i've use shorter pieces of liner like you're talking about just through the guide, that works great w/ internal routing. currently i've got full length liners from where the housing enters the down tube. you can see it very well because of the SRM magnet, but you get the idea.
FMF 24" cruiser
'05 Suzuki DRZ400SM
This is a (9)spd 6500 r. der.
I set the chain on the (12) tooth cog and the cable ran a nice straight path from the exit point on the der. to the clamping bolt.
I set the chain on the (25) tooth cog (the biggest cog), and again the cable ran a nice straight path.
(no comments about the need for washing, it's actualy dust on a bike that doesn't see much action)
This is a (9) speed r. der. on my CX bike.
Same results as above. The cable always ran a straight path to the clamp bolt.
So whats up with that sever angle seen on the more modern designs?
I suppose they calculate that a stainless steel cable rubbing the alloy of a der. body is inconsequential?
Why not stay with the straight cable path design.
Anyone found an on-line source for the new D. Ace 9000 shift cables?
QBP still doesn't show them yet. usually they have a part#/description/eta up for something like that, but they don't even exist in the catalog yet. the brake cable/housing are on the catalog but show an eta of 4/19/13.
FMF 24" cruiser
'05 Suzuki DRZ400SM
Good afternoon,
Thank you for your email.
I can confirm that we will be getting this, however at this moment in time we do not have a new delivery date.
We do apologise for any inconvenience caused.
I ordered three sets of the brake cables from BlueSky. Before ordering, I emailed and got this response.
''Hello,
The housing and cables are Dura-Ace. The imprinting on the cable housing reads: Shimano BC-9000.
If you have any further questions, please feel free to email or call us 1-800-585-4137
Regards,
Tech Team''
Hopefully they're the real deal. I ordered some Dura-ace 7700/7800/7900(non-PTFE) shifter cables from amazon (seller Xtreme Bike & Sport), however they were black and not the grey I need (okay, 'want') to match the brake cables. So I've sent them back. They were listed as gray.
This whole chasing up cables has been a huge pain, so if the BlueSky ones are genuine, I'll get a heap more and the same when the shifter cables come out (and are on special). I don't want to have to chase genuine shimano cable kits again ... I now see a major advantage in electronic ... no more changing cables!
