Results 1 to 8 of 8
    Reputation: siclmn's Avatar
    Dura Ace sprockets on a Ultegra Freewheel?
    Can I do this on my DI2?
    Will it give me the "glide" on properties when I shift?
    Or is it more complicated then I think?
    Having had Dura Ace years ago I miss how well it shifts.
    Carbon Fiber = Explode!
    Reputation: CleavesF's Avatar
    Dec 2007
    Yes. The spacing between cogs should be the same.
    Anything that's the same "family of speeds" should be interchangable. Obviously this is rare to do with individual cogs and a whole carrier, but I don't see why it wouldn't work unless there's a proprietary spline/hub that I don't know about.
    '09 Voodoo Wazoo
    '08 Pedal Force RS2
    '06 Raleigh Cadent 5.0
    '01 Trek 4300 MTB
    '93 Norco Nitro MTB Touring
    '88 Schwinn Prelude Fixie
    1 hour of running = 1 hour of wasted time when you could have been riding. - Alaska Mike
    Feb 2002
    Quote Originally Posted by siclmn View Post
    It will work fine. But the obvious question is why on earth you would pay so much more for DA cogs that will wear out so much faster and not shift any better.
    'brifter' is a lame word.
    as the others have said, yes...it will work. but as Kerry asked, why? the Dura Ace cassette is 3 times the price of the Ultegra and there is NO difference in shifting, only weight. and as Kerry said it won't last as long.
    I work for some bike racers
    and a bunch of skateboards
    If you have Di2 and miss the way your Dura Ace shifts from years ago you either need an adjustment or need to get used to the difference between mechanical and electric. I don't really know what a "glide on property" is but if you're looking for electric to feel just like an old mechanical set....it ain't going to happen.
    A Dura Ace cassette will do nothing to improve or change the feel of your shifting unless perhaps your ultegra one is worn out but in that case a new ultegra one would have the same impact.
    For the price of a new DA cassette you could probably buy back your old DA that you miss.
    Using the words "glide on" I meant to say, when you change gears under power it shifts smoothly rather then the kerchink sound that Ultegra makes. I always thought it was the different angle of the teeth on Dura Ace that made it sound that way. They have always designed DA that way to make it feel better than Ultegra. If you have never had DA then you won't know what I am talking about.
    wim
    wim is offline
    Feb 2005
    It may well be true that Dura-Ace shifted more smoothly and quieter for you under power than Ultegra. But as others have said, this almost certainly had nothing to do with the cassette.
    you are confused. in the last 15-20 years there has been NO difference between D/A and Ultegra cassettes other than materials. the design of the cogs, their shape and profiling, has been EXACTLY the same.
  1. New Ultegra vs used Dura Ace
    By nbd1980 in forum Components, Wrenching
    Last Post: 05-03-2013, 04:42 PM
  2. Dura Ace Hub / Freewheel Problem
    By manthei2 in forum Components, Wrenching
    Last Post: 06-21-2010, 12:06 PM
  3. Campy Cassette/freewheel & Ultegra
    By comsense in forum Components, Wrenching
    Last Post: 12-22-2008, 04:26 AM
  4. Dura Ace vs Ultegra
    By obsessed in forum Components, Wrenching
    Last Post: 11-29-2007, 07:19 AM
  5. ultegra sl with dura ace bb and regular ultegra chain
    By revolator in forum Components, Wrenching
    Last Post: 10-26-2007, 12:24 PM
