Results 1 to 14 of 14
    May 2004
    favorite citrus degreaser?
    are they all the same strength? Or do some work better than others?
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    I've only tried the Park Tools version (Chain Brite?), but it was strong enough to do the job quite well. I would imagine they're all more or less the same strength...pretty hard to go wrong there.
    "Luminous beings are we...not this crude matter!"
    Not a rocket surgeon.
    Nov 2008
    For what?
    General cleaning?
    Grease?
    Dish soap cleans the frame.
    OMS for the grease.
    Citrus? Maybe for the vodka.
    Jan 2009
    Pure citrus solvent is a chemical called d-limonene. It's chemically similar to turpentine, and is clear though it may have an yellow or orange tint. It's fairly expensive, and is a very strong solvent which will break down oils, greases and waxes, but it works best when used in it's pure state.
    However many commercial versions stretch it with water and/or petroleum distillates. Adding water to limonene makes it cloudy or milky, so it's clarity is an indicator of it's purity.
    You can buy d-limonene from a number of sources, but read labels carefully so you get what you pay for.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Moderator
    Sep 2007
    I use the Finish Line citrus cleaner - the liquid version, not the aerosol. It is amazing at removing grease and other gunk without damaging the finish. I use very sparingly and generally clean off with alcohol afterwards. A bottle of it will last for years. And it smells good too.
    Old La Honda in less than 20 minutes! Or you can watch race video from the low-key hill climb on Welch Creek. More at www.biketelemetry.com.
    "I think," said Christopher Robin, "that we ought to eat all our Provisions now, so that we shan't have so much to carry.", Winnie-the-Pooh, A. A. Milne.
    Aug 2006
    I like the Pedro's and Park Tool degreasers.
    Resident Curmudgeon
    Nov 2005
    I've never used one. My "go to" is OMS.
    Don't believe everything you think.
    No Bonk Zone
    Reputation: Doolab's Avatar
    Feb 2008
    I use the Zep Citrus Cleaner from Home Depot. Works very well in cleaning my bikes and is much cheaper than the stuff I was buying from my LBS.
    debonked.
    Jan 2012
    I usually use Simple Green to wash my bikes when they need more than a polishing, but when removing black grime I usually prefer Finish Line's citrus degreaser. I haven't tried many others as that was what most of us at the shop used, but it worked very well.
    pmf
    pmf is offline
    Quote Originally Posted by Doolab View Post
    Bingo. A gallon costs $9. It lasts forever. I've been using this stuff for years. I use it straight out of the bottle, undiluted. It is very effective at degreasing your bike without harming any metal or paint.
    probikesupply
    Guest
    The best we have used is Dumonde Tech Bio Green Citrus Solvent. You only need about 2 oz to fully clean a chain from nasty to brand new.
    1.) Take an empty Orange Juice or other 1-2L bottle
    2.) Pour in your 2oz of Dumonde Tech
    3.) Put the chain in and screw the lid back on.
    4.) Shake the hell out of it for 1-2 minutes and let it sit for a few more.
    5.) Remove the chain and rinse it off.
    Looks new and you can repeat the process with the same liquid many times. This stuff is powerful.
    Re-Cyclist
    Reputation: Special Eyes's Avatar
    Feb 2011
    I went to my hardware store and bought a gallon of whatever citrus cleaner they had. Works great. Probably all the same. I NEVER put it on my bike, only use it to clean components of the bike or lightly wet a rag and clean some parts on the bike. Frame, fork, wheels never see solvents.
    Santa Barbara, CA -- My Photo Site -- My Business Site
    Apr 2010
    Quote Originally Posted by trekracer20 View Post
    I put a chain in simple green diluted 5:1 in a bottle and forgot about it for 24 hrs or so. I took it out and some of the rollers were discolored, but still seem to work fine.
    I'm not sure what simple green has that does that, but I'm not getting it near my frame.
    It's a fire road.............
    I'm on a road bike..........
    They have enough in common to blast down it.
    Nov 2008
    Simple green is bad stuff.
    Corrosive.
    Not a fan.
  1. Favorite degreaser
    By dtaffe in forum Components, Wrenching
    Last Post: 04-29-2011, 07:41 PM
  2. citrus chain degraser
    By frank bautista in forum General Cycling Discussion
    Last Post: 08-22-2010, 01:03 PM
  3. Diet Lipton Green Tea w/Citrus
    By bmxhacksaw in forum The Lounge
    Last Post: 05-13-2010, 11:12 AM
  4. Best Degreaser?
    By johngfoster in forum Components, Wrenching
    Last Post: 04-12-2006, 05:28 PM
  5. Citrus Degreaser
    By moosryan in forum Components, Wrenching
    Last Post: 04-11-2005, 04:46 PM
Sea Otter Classic
Contest
