Results 1 to 3 of 3
    Mar 2013
    fix broken chain link?
    hi, my chain just broke from shifting under pressure; one of the links is bent out of shape. would the removal of the link with a chain tool affect the drivetrain?
    Oct 2011
    Depending on how your chain was originally sized, it may make it too short. The problem with that is if you accidentally (or on purpose) shift into big-big, you could bend the rear derailleur or pull it into the spokes.
    You also need to be sure to put it together properly if it needs a master link or a special repair pin (as for Shimano chains for 9,10 or 11 speeds (I'm not sure about 8)).
    Reputation: matfam's Avatar
    Jul 2012
    Just replace the chain. If you do remove a link and it is to short when you accidentally shift to the big-big combination, you could break the rear derailleur.
    People sleep peaceably at night because rough men and woman stand ready to do violence on their behalf. George Orwell
    Oregon Bike MS 2013 Team Matfam
  1. How to fix bad chain link?
    By Tahoe Gator in forum General Cycling Discussion
    Last Post: 04-01-2013, 04:06 AM
  2. Trek 6000 broken chain=broken gears?
    By Johnstrek6000 in forum Trek
    Last Post: 08-01-2012, 08:26 AM
  3. Installing quick-link on broken 11 speed chain...how to?
    By G**G in forum Components, Wrenching
    Last Post: 05-28-2011, 12:12 PM
  4. Broken chain - KMC?
    By ridewt in forum Components, Wrenching
    Last Post: 04-03-2009, 10:48 AM
  5. Need help from chain gurus (connex link+ record UN and shimano chain)
    By hppy4u in forum General Cycling Discussion
    Last Post: 10-23-2008, 06:54 PM
Sea Otter Classic
Contest
