Results 1 to 8 of 8
    Jul 2013
    Flattened/ovalized handlebars - are they stiff enough?
    https://ritcheylogic.com/wcs-streem-2-blatte-road-bar
    Take a look at this product (above).
    Some road handlebars are flattened a little in order to make them more aerodynamics and give your hands a larger platform. Presumably this weakens the handlebar in the up/down direction.
    Are these handlebars stiff enough (and strong enough) to handle the same amount of forces as those whose tubing is circular? I'm talking about a 200+ pound rider who can really pull hard on them in a sprint.
    Reputation: SilverStar07's Avatar
    May 2011
    I don't have any experience with the bars above but I have the 3T Aeronova Team Stealth https://www.3tcycling.com/road/en/bi...-team-stealth/ , really flat tops on my race bike and Zipp SLC2 Zipp - Speed Weaponry | Bars | SLC2 Bar ,round bars on my other bike and I notice more flex with the Zipp's. I weigh anywhere between 205-220lbs depending on how late in the season it is. I have not noticed any flex out of the 3T's and the flex I get with the Zipp's is very little. I think it has less to do with shape and more to do with design and construction. I know there are certain bars designed to have some flex, similar to how bike manufactures design in vertical compliance into their frames.
    SS-
    My quest for 140.6 and passion for all things cycling https://multisportunleashed.blogspot.com/
    2015 Felt AR3 upgraded to Ultegra 6870 Di2
    2011 Specialized Secteur Elite Apex -Just about how I want it
    2005 Iron Horse MK3 Expert - many years of trail duty and still my go to Mt. Bike.
    CX'er
    Reputation: bikerector's Avatar
    Oct 2012
    I wouldn't hesitate to buy those, being a larger sprinter myself (220-230 clyde sprinter). I'm actually using some old, 2012 or so ritchey WCS Logic carbon bars that have lasted surprisingly well considering how thin they are and how much I've reafed on them in training and racing.
    They do flex a little but not horribly and it's far from noticeable while actually riding, more so on the trainer when everything locked into place. Probably the only time i notice it on the road is doing over-geared starts which is supposed to be like strength training on a bike. Sometimes during hill sprints.
    I know a pro rider that was on the 35mm bars and stem from deda and he mentioned them being almost too stiff and needed time to adjust to them. I imagine the different would be like going from a slightly flexy frame/wheels to a stiffer race frame/wheels when out of the saddle and yankin on stuff. The stiff bars probably felt more direct in there transmission of arm inputs in the vertical dimension.
    coaster
    Reputation: Lelandjt's Avatar
    Sep 2008
    My Eston EC90 Aero handlebars have very thin wing shaped flats but I don't feel it flex any more than other bars.
    tka
    tka is offline
    Jun 2014
    Quote Originally Posted by Waspinator View Post
    I ride those exact bars. I'm 180 and an okay sprinter. When I pull on the bars I notice no difference between the Streem 2 and any of my round cross-section bars. I do really like the flats on the tops, however. That and the overall shape make these one of my favorites.
    May 2007
    You're right to be concerned, since strength of a beam is highly related to the thickness.
    I had some TTT Aeronova knockoff bars that broke on a defective cattle crossing. I'm very surprised I didn't fold a rim it was such a shock.
    Readers feel free to attribute the break to the fact that these were Asian knockoffs, but I've done a lot of carbon layup work and didn't see anything to indicate that these were faulty in materials or craftsmanship. I'll leave it up to the jury.
    However I will make these notes:
    - I wouldn't worry about a 200lb rider pulling hard, but I would worry about the instantaneous shock of a large hit like I took, which can be severe from a moment-arm perspective. FYI I'm 155lb.
    - The bars failed in compression exactly where you would expect, near the stem where the airfoil shape was still thin and moment was highest. Carbon is much stronger in tension than compression, so the bars will tend to collapse on the underside.
    - The bars did not fail catastrophically; things remained attached, I did not go down.
    - The break was (IMHO) highly exacerbated by bad placement of cable exits exactly where you don't want them; at the highest compression point in the design. The break exactly traversed these exit holes which presented stress-risers. I will never buy carbon bars again with the exit holes underneath the bars. My new S-Works bars smartly have the exit in the middle of the trailing edge, which has the lowest shear in the 'beam'.
    - As far as I know, all TTT Aeronovas, whether legit or knockoff, have the exit holes in the same place.
    Here I've broken them apart after removal. Note the break passing through the cable exit hole.
    Flattened/ovalized handlebars - are they stiff enough?-img_1179.jpg
    Flattened/ovalized handlebars - are they stiff enough?-img_1178.jpg
    Attached Thumbnails Attached Thumbnails Flattened/ovalized handlebars - are they stiff enough?-img_1186.jpg
    tka
    tka is offline
    Jun 2014
    ^ Sounds like a nasty failure but I'm trying to figure out how it applies to a 7075 alloy ovalized bar with no internal routing holes?
    May 2007
    I don't think it applies to ovalized aluminum bars. They should be bulletproof and more accommodating of shock loading.
    I was thinking more broadly about Google hits to this thread...it's a reasonable place to share my experience.
  1. Flattened tires
    By pixie359 in forum Wheels and Tires
    Last Post: 07-09-2014, 08:58 AM
  2. ovalized head tube?
    By dspaulson in forum Components, Wrenching
    Last Post: 12-09-2008, 07:59 PM
  3. Stiff handlebars under 60?
    By mcmcderm in forum Components, Wrenching
    Last Post: 10-08-2008, 03:23 PM
  4. Replies: 12
    Last Post: 05-23-2008, 07:27 AM
  5. Stiff handlebars without too much weight penalty?
    By Vinokourov in forum General Cycling Discussion
    Last Post: 01-05-2006, 09:23 AM
