Results 1 to 10 of 10
    Aug 2012
    Flip any adjustable stem ?
    Can you flip any type of threadless, adjustable stem -- and use it right-side-up OR upside-down?
    Or are there some types that you can't flip?
    Thanks
    Feb 2002
    Quote Originally Posted by SubRider View Post
    What do you mean, "threadless adjustable stem" There are only a couple of adjustable stems on the market and they are rarely used.
    But if you're talking about general threadless stems then yes, you can flip them if you want to. Some may end up the the stem pointing down toward the front wheel but you can ride that way if you want.
    Aug 2012
    Yes, I'm referring to adjustable threadless stems, not adjustable quill-type stems.
    Pathlete and Pedalphile
    Reputation: redondoaveb's Avatar
    Jan 2011
    If it's an adjustable stem, why would you need to flip it?
    If you try to fail, and succeed, which have you done?
    Cumudgitude
    Reputation: UrbanPrimitive's Avatar
    Jun 2009
    The question in the minds of many people reading this is whether you're talking about an adjustable stem or a fixed stem, not threadless versus quill.
    If it is indeed an adjustable stem my understanding is the ratchet mechanism does have a bottom side with a robust mechanism to lock the stem into place once the desired angle is achieved. I could be wrong on this, but I think the directional force is used to ensure the locking plate is jammed into place. It's not necessary for force to be applied for it to feel firm, but force in the opposite direction probably wasn't accounted for in the design.
    That's my stab in the dark, assuming we're talking about what I think we're talking about.
    If you only ride in nice weather you're missing a lot of fun.
    Quote Originally Posted by Tig View Post
    Had fun building up a bike... Check!
    Having fun riding... Check!
    The rest is just details.
    Aug 2012
    I want to lower the handlebar more than my flipped fixed stem.
    Since I'm not sure of how much lower, and because my current adjustable stem cannot go lower than my flipped fixed but can go higher (right-side up), flipping the adjustable stem will provide for lowering the bars--if it is safe to do it.
    Aug 2012
    Urban,
    My adjustable stem has a locking wedge that doesn't look like it was designed to handle being flipped.
    I'm really asking whether there is a type that is safe to flip.
    Jan 2011
    Urban,
    What about this Ritchey.
    Ritchey Logic - Road - Stems - Ritchey Adjustable
    Reputation: looigi's Avatar
    Nov 2010
    ...My adjustable stem has a locking wedge that doesn't look like it was designed to handle being flipped...
    That occurred to me too, but riding you can pull on the bars nearly as hard as you push, so it has to be able to take the force in either direction, which suggests it is flippable.
    ... 'cuz that's how I roll.
    Hucken The Fard Up !
    Reputation: Salsa_Lover's Avatar
    Jul 2008
    there is a confusion of terminology here.
    this is an adjustable stem
    this is a normal -6 stem
    if that doesn't put your bars enough low, try a -17 stem
    if that is not enough, use a pista ( -26 stem )
    Hope that helps
    Quote Originally Posted by zank
    They're just bikes. Ride 'em in the rain, salt, snow and crap to fully appreciate them.
    Quote Originally Posted by Sean Kelly
    The thing about the cold is that you can never tell how cold it is from looking out a kitchen window. You have to dress up, get out training and when you come back, you then know how cold it is.
  1. Adjustable Stem????
    By real stonie in forum The Lounge
    Last Post: 07-26-2011, 01:00 PM
  2. Swapping adjustable stem ?'s
    By tober1 in forum Components, Wrenching
    Last Post: 02-27-2010, 07:25 AM
  3. Stem: To flip or not to flip? (pros and cons)
    By texass4 in forum Beginner's Corner
    Last Post: 03-11-2006, 07:48 PM
  4. Adjustable Stem Angle
    By CBar in forum Components, Wrenching
    Last Post: 11-29-2004, 07:23 PM
  5. 31.8 Adjustable Stem ??
    By msohio in forum Components, Wrenching
    Last Post: 11-28-2004, 07:04 PM
Sea Otter Classic
Contest
