Results 1 to 2 of 2
    Aug 2009
    Force CX1 Crankset with SRAM Direct Mount Chainring
    There is very little info available on using SRAM direct mount chainrings on Force CX1 cranks. I wanted a 36t front ring for my wife's bike but the smallest standard ring is 38t. After a lengthy search online, I decided to give it a shot and ordered a 36t direct mount chainring with 6mm offset. It took longer to pull the cranks than it took to swap the ring, but I'm happy to report that it's a perfect match and 50g lighter as well. Chain line is now 1mm closer to the frame, centered on the cassette, and shifting is perfect. Success.
    Reputation: bon_gabs's Avatar
    Feb 2010
    Oh Man,,Thanks for this post,Ive been searching for info about this set-up finally its confirmed that it will work,by the way mine is the BB30/PF30 Force crank,not sure if this will work the same..LoL
    Quote Originally Posted by waterlogged View Post
  1. Replies: 1
    Last Post: 02-09-2015, 03:31 AM
  2. Can you run 11s xglide chainring on a 10s force crankset?
    By lwkwafi in forum Components, Wrenching
    Last Post: 02-08-2015, 11:30 AM
  3. Sram Red vs. Force/Rival big chainring
    By ssing20 in forum Components, Wrenching
    Last Post: 07-08-2010, 09:08 AM
  4. FSA SL-K Light Crankset + SRAM chainring
    By danahs in forum Components, Wrenching
    Last Post: 11-18-2009, 06:44 PM
  5. SRAM Force Crankset VS. Ultegra SL Crankset
    By floridacyclist in forum Components, Wrenching
    Last Post: 10-13-2008, 06:48 PM
