Results 1 to 7 of 7
    Sep 2017
    Front derailleur
    Hi, I have a Sram red 2010 crankset with Extralite chainrings (because I wanted a 34-50 combo) and a Sram red 2010 front derailleur (which has known problems with shifting). I ordered a Sram red 2013 derailleur with Yaw technology which sould work better but got the same 2010-2012 derailleur that is allready on my bike. As I cannot find any new Sram derailleur (with Yaw) with a clamp (I need a 34,9 mm clamp) and I dont want to spend money on extra parts (buying the clamp separately) I was thinking gooing with Shimano. I read it works.
    But should I go with the 10-spd Ultegra 6700 derailleur or the newer 11-spd Ultegra 6800 which cost almost the same? Which one would work better with the Sram red 10-spd shifters?
    Thank you for your help.
    Peter
    'brifter' is a lame word.
    Quote Originally Posted by ppahor1 View Post
    Peter
    Your shifters won't work perfectly w/ a YAW derailleur. I'd get a non-YAW steel cage Red or Force derailleur. Either one of those will work great.
    I work for some bike racers
    and a bunch of skateboards
    Sep 2017
    I read that the yaw derailleur works better even with the old shifters.
    It works! We test SRAM Red backwards compatibility | VeloNews.com
    I do not trust Sram and I would prefer to install a Shimano derailleur if it would work. Does anybody have any expirience with this?
    You don't trust SRAM? What's that supposed to mean?
    Sep 2017
    The Sram red 2010 I have on the bike is awfull (and was mounted by a good mechanic). And I read a lot of stories about Sram and poor shifting on the front derrailleur (and even pro riders not using the first models of Sram red on the front) which apparently improved after the introduction of yaw technology. That's why I am afraid that even a pre yaw Sram force will not work as good as a Shimano derailleur.
    Peter
    Off the back
    Reputation: fast ferd's Avatar
    Jan 2009
    Sram derailleurs work fine. You could find a Shimano 34.9 adaptor on eBay for cheap. These work well and hardly constitute extra parts.
    Peter
    The original Ti cage Red derailleur was the one that sucked. The pro teams had the option to use the 'Red front derailleur, steel cage' that was basically a Red link w/ a Force cage. I still have a couple laying around somewhere, I ordered a ton of them for teams I worked for. It's exactly the same as any Shimano derailleur and will work just as well. Either brand will get the job done for you.
  1. Shimano 5700 105 front shifter With 5800 105 front derailleur ?
    By bbohr in forum Components, Wrenching
    Last Post: 08-16-2016, 07:34 PM
  2. Front derailleur front-to-back angle?
    By ctslater in forum Components, Wrenching
    Last Post: 04-07-2014, 03:41 AM
  3. Replies: 5
    Last Post: 07-11-2012, 04:11 PM
  4. How to Attach 105 rear derailleur to derailleur hanger?
    By Jayzonk in forum Components, Wrenching
    Last Post: 06-26-2009, 05:33 PM
  5. Campy QS Front Shifter with Shimano Front Derailleur
    By HammerTime-TheOriginal in forum Components, Wrenching
    Last Post: 01-08-2007, 10:23 AM
