Results 1 to 3 of 3
    Jun 2013
    Front Derailleur Problem
    Hello,
    I'm having a problem with my front derailleur/shifting system. My road bike has 2 chainrings. Whenever I go to shift into the large chainring, my front derailleur moves the chain onto the large chainring (as it should), but whenever I release my shifter, the front derailleur moves back inwards, pushing the chain back down onto my small chainring.
    So basically, my chain only stays on the large chain ring if I hold the shifter up, but as soon as I release, my shifter falls, and the front derailleur moves the chain back down. This is clearly a problem.
    Attached Thumbnails Attached Thumbnails Front Derailleur Problem-bike4.jpg   Front Derailleur Problem-bike3.jpg   Front Derailleur Problem-bike2.jpg   Front Derailleur Problem-bike1.jpg
    Dec 2010
    Your gear levers look like they are in rough shape. Maybe they are loose and can't resist the spring tension in the derailleur.
    Reputation: .40AET's Avatar
    Aug 2008
    I can't tell from the photo, if there is a screw on the side, tighten it and it should add tension to the shifter.
    Good luck
  1. Front Derailleur Problem
    By Panther25423 in forum Beginner's Corner
    Last Post: 06-15-2013, 10:41 AM
  2. Front derailleur problem
    By girlyman in forum Components, Wrenching
    Last Post: 11-16-2008, 06:22 PM
  3. Front derailleur Problem
    By StickManJones in forum Beginner's Corner
    Last Post: 05-31-2008, 04:54 PM
  4. Front Derailleur Problem?
    By Edster in forum Campagnolo
    Last Post: 02-22-2008, 10:15 PM
  5. Front Derailleur problem
    By scfishy in forum Beginner's Corner
    Last Post: 07-25-2005, 11:16 AM
Sea Otter Classic
Contest
