Hello all! Brand new forum member here. I'm also a brand new rider. I've purchased my very first road bike online via bikesdirect.com. I have the Windsor Wellington 2.0. I've got the bike all assembled and I'm having one heck of a time with the front derailleur. I've watched probably around 50 youtube videos about adjusting it but I'm simply not having any luck. I finally had the bike shifting on all three crank rings with no load and after taking the bike around the driveway for the first time it will not shift at all. The derailleur is shifting but the chain simply rides against the side of it and does not shift. I'm frustrated to say the least. When I first got the bike assembled the shifter would only get the chain onto the smallest and second crank ring. The derailleur would not shift the chain up to the largest. After my youtube marathon of videos I finally got it to shift through all three rings. Now, 30 minutes ago I took the bike out for the very first time just up and down the drive and it will not shift the chain to anything but the smallest crank ring.What do I need to do?
Here is what I did when I first started into trying to adjust it:
1. Shift the derailleur to the smallest crank ring.
2. Remove the shift cable.
3. Align the derailleur using the limit screw over the smallest crank set.
4. Reattached the shift cable.
5. Shifted the derailleur to largest crank ring.
6. Aligned using the limit screw over largest crank ring.
7. Shifted to the middle crank ring.
8. Tweaked the barrel adjuster to center over the middle crank ring.
I had everything working under no load just fine. Once I got on it and rode it for about 10 minutes (with no shifting at all) I tried to shift to the second crank ring and it just moved the derailleur up and the chain remained on the smallest crank ring rubbing the derailleur. I got completely off of the bike and lifted it with one hand and shifted it back down to the smallest crank ring and attempted to shift it up to the second and it did the very same thing, moved up but the chain stayed and rubbed. I am obviously doing something wrong. Any help or insight will be greatly appreciated. I'm no bicycle mechanic but I do have several years experience as a diesel mechanic so I'm not completely oblivious but this has me frustrated and confused. Thank you in advance.
Results 1 to 8 of 8
Hot DealsLatest RoadBike ArticlesLatest VideosRoadbikeReview on Facebook |
LinkBack URL
About LinkBacks
