Results 1 to 3 of 3
    Jack of no trades
    Reputation: Wood Devil's Avatar
    Apr 2011
    Question Garmin Vector 2s Installation -- This may seem like a dumb question...
    I just installed the Garmin Vector 2s pedals on my bike.
    Now I just need to figure out where to put my speed/cadence sensor. I have the Garmin speed/cadence, but before installation, I had a small magnet over the pedal bolt. Can't do that anymore because the pedal pod plug is not there. So I have to go back to the old magnet that you need to use a zip tie to secure to the pedal.
    My question is: Would having a magnet so close to the Vector pedal pod mess up power readings?
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by Wood Devil View Post
    My question is: Would having a magnet so close to the Vector pedal pod mess up power readings? Should I just move the Garmin cadence sensor to the front wheel?
    You don't need cadence from the speed/cadence sensor. The Vector with record your cadence.
    Just use the speed/cadence sensor with the wheel magnet to record speed. Eliminate the crank magnet.
    Forever a Student
    Mar 2014
    Eliminate the whole speed/cadence sensor setup.
    GPS device will track your speed.
    Power meter will track your cadence.
    Get that crap off of your bike.
    use a torque wrench
  1. Replies: 2
    Last Post: 06-16-2014, 04:22 PM
  2. Garmin Vector Question
    By RyanM in forum General Cycling Discussion
    Last Post: 04-22-2012, 02:15 PM
  3. Replies: 3
    Last Post: 06-05-2006, 06:13 PM
  4. Rolf Vector Pro Vs. Vector Comp Wheels?????
    By bowler1 in forum General Cycling Discussion
    Last Post: 09-05-2005, 11:38 AM
