Results 1 to 8 of 8
    Sep 2016
    Gluing Quarq magnet to carbon frame
    I want to install a magnet for my Quarq on a carbon frame. Is there a recommended adhesive that I can get off the frame if needed?
    Jan 2009
    I wrapped electric tape around the cadence magnet/chain stay.
    pmf
    pmf is online now
    Years ago I had wheels with big carbon spokes (Spinergy Rev-X). I glued a magnet on the front wheel using tubular tire cement. It worked great, and I was able to get it off when I wanted to.
    Jul 2013
    If gluing I'd use RTV or something of the likes.
    But, you could use this too: Pro Braze-on Chain Catcher with SRM Magnet | K-EDGE
    I use it for my SRM but others with a quarq reported it works fine for them. No gluing, no worrying about it falling off or getting knocked off.
    Aug 2013
    Newer quarqs (most recent and prior generation) do not require a magnet.
    Sep 2016
    Quote Originally Posted by crit_boy View Post
    I have those Quarqs but I hear it's more accurate with the magnet. I'm also having an issue on one of my bikes with the Shimano shift plate for the front derailleur constantly falling off so I want to glue that as well.
    Jul 2012
    Couldn't you use the clear silicon that you would normally use for sealing bathroom and window? A small dot is all you need.
    'brifter' is a lame word.
    Quote Originally Posted by alxrmrs View Post
    You heard wrong. If anything having a magnet on a newer Quarq will make it worse. That comes directly from SRAM's road product manager.
    ETA: The plate under the support screw? How can it fall off if the derailleur is installed correctly? Hint: There is only one correct answer.
    I work for some bike racers
    and a bunch of skateboards
  1. New Carbon Wheel Gluing issue
    By rudedog55 in forum Cyclocross
    Last Post: 04-19-2014, 07:52 AM
  2. carbon rim damage from gluing tape
    By mrfox in forum Components, Wrenching
    Last Post: 06-08-2013, 11:01 AM
  3. cadence magnet damaged my frame
    By jkmacman in forum Bikes, Frames and Forks
    Last Post: 10-04-2010, 10:46 AM
  4. Re-gluing carbon tubulars?
    By rainracr in forum Wheels and Tires
    Last Post: 02-27-2007, 02:27 AM
  5. Gluing carbon tubulars: Zinn article repost/paraphrase?
    By dawgcatching in forum Wheels and Tires
    Last Post: 08-03-2005, 03:03 PM
