Results 1 to 6 of 6
    Jan 2013
    Question Handlebar, Shifters, Stem questions
    Hello, I'm a noob.
    My old commuter got stolen, so I bought a bike that I thought would be cool. I didn't really like the handlebars and shifters. I tried to fix the shifter and broke it. I want to set it up with handlebars and shifters that I would like. I have some questions about compatibility.
    Would these parts be compatible?
    • 8 speed shimano sora rear derailleur
    • MTB trigger shifters such as:
    • 25.4 stem clamp & 22.2 brake clamp Handlebars such as:
    • 26mm stem with a shim to clamp to the 25.4 handlebars
    Thanks for any help. My deadline for leaving is April 3, so I may have to scrap this project.
    New question: Would a SRAM derailleur be compatible on the shimano cassette?
    Reputation: Mr_Clean's Avatar
    Feb 2012
    For sure, you won't be able to run your SRAM shifters with your Sora RD. their actuation ratios are different. You may however, find old SRAM gripshifts that are compatible with Shimano.
    Jan 2013
    is there any way to use trigger shifters with the Sora RD? I've heard there are those little rotating circles that change the travel travel of the line by changing to a different arc radius. Would those or anything else work? I feel like trigger shifters are the best option because they're cheap, comfortable, and functional.
    Reputation: crossracer's Avatar
    Jun 2004
    I believe sram makes shimano compatable trigger shifters. But im not at work to look it up right now. If no one answers by tommrrow ill look up and get you an actual answer.
    Bill
    Feb 2012
    The older SRAM Attack shifters will work with Shimano. The X4 won't.
    Jan 2013
    Thanks for the input guys. I found this with google:
    Mixing SRAM shifters and Shimano derailleur - Bicycle Repair Forums
    The SRAM website does indicate the compatibility:
    Trigger Shifters | SRAM Mountain | SRAM
    Interesting video:
    Sram Trigger Shifters mounted on a Panasonic 1987 road bike - YouTube
  1. Integrated handlebar (stem+handlebar) VS seperate?
    By lightweight in forum Components, Wrenching
    Last Post: 07-03-2011, 08:56 PM
  2. SRAM Shifters and Handlebar Compatability
    By Asmodeus2112 in forum Components, Wrenching
    Last Post: 12-14-2009, 03:08 PM
  3. Handlebar & Stem help
    By RyanM in forum Components, Wrenching
    Last Post: 07-27-2009, 12:15 PM
  4. Stem 25.8 mm and 31.8 mm handlebar...
    By bianchi77 in forum Components, Wrenching
    Last Post: 06-04-2009, 04:56 AM
  5. Handlebar and stem...
    By ringroadwarrior in forum Components, Wrenching
    Last Post: 05-27-2009, 04:14 PM
