Results 1 to 9 of 9
    Aug 2018
    Headset conversion from cage bearings to cartridge
    I am new to road biking and the site and I'm looking for info on converting a (low cost) caged bearing headset to a cartridge style. I have a 2017 Giant contend and could not locate and model specific info on Cane creek's site or the FSA website. Any info would be greatly appreciated.
    hfc
    hfc is online now
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    It is unusual to have to replace a headset on a one year old bike. Do they even used caged bearings on new bikes now? If you need to replace the bearings, take the old cage out, take it to the bike shop, ask for a similar replacement. As an alternative you can ask for loose bearings in the same same size, add one ball to take of the slack from the cage.
    Feb 2002
    Quote Originally Posted by Stevieray05 View Post
    Think this through. A cartridge bearing cross section is roughly square, often with chamfered edges. This fits into a matching space in the frame. There is no bearing race in the frame when you have a cartridge headset. When you have a ball bearing headset, the upper and lower cups are pressed into the head tube and when removed, you see the open end of a simple tube - no place for a pressed in cartridge.
    If you don't like having caged ball bearings, then figure out what size you have a buy enough to fill the upper and lower races. You can also buy high quality ball bearing head sets.
    'brifter' is a lame word.
    OP can you post some pics of your bike? I'm pretty sure you have cartridge bearings already and what you may be seeing is that one of them has come apart. Every photo I've seen of the Contend shows what is an integrated headset which would have cartridge bearings. There are no visible headset cups that would hold caged ball bearings.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2018
    The headset is not in bad shape. Looks like the bearing were dry though and the lower race has some rust. I cleaned and re greased and the action is smooth....there is a slight creaking though. I figured a new cartridge set would be a nice upgrade, not to mention they hold up better in the wet weather.
    Aug 2018
    I have the bike together and unfortunately did not take pics. I went through and took several measurements with my caliper to see if I can get a replacement. There is races pressed into the frame, so from the outside it looks like a semi-integrated cartridge set up. There are two caged bearings and two inner races that all come apart. The cups act as the outer races.
    I cleaned and greased all the surfaces and the headset works smooth but there is a slight creak I would like to get ride of.
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Stevie, if you haven't, you might try regreasing the handlebar clamp, the stem/fork, and the brake levers; their joinings may be the source of your creak, rather than the headset.
    Donald Trump has never had a wife he didn't cheat on.
    Aug 2018
    I will give that a try. I grease all the screws but it did not make a difference. Thank you
    xxl
    xxl is offline
    Moderator
    Mar 2002
    Tracking down creaks can be maddening, as sounds seem to be conducted across the bike. One will swear the creak is coming from one place, and it ends up coming from another. Handlebar creaking is pretty common, due to the leverage one can exert on the bar/stem, while fork creaking, not so much, so I'd start there.
    Also, if you search on "eliminating annoying creaks," there are a number of good tips on narrowing down the sources of creaks. Best of luck, we've all been there.
  1. Cartridge Bearings - Headset indexing?
    By Camilo in forum Components, Wrenching
    Last Post: 05-11-2010, 11:54 AM
  2. Headset cartridge bearings: re-lube or replace?
    By llama31 in forum Components, Wrenching
    Last Post: 11-10-2006, 06:29 PM
  3. Replies: 1
    Last Post: 12-07-2005, 05:21 PM
  4. Headset maintenance needed if cartridge bearings?
    By NoMSG in forum Components, Wrenching
    Last Post: 12-31-2004, 06:17 AM
  5. Sealed bearings, sealed cartridge bearings?
    By girishji in forum Components, Wrenching
    Last Post: 03-16-2004, 07:44 AM
