Results 1 to 10 of 10
    HELP! Handlebar "Reach" - What does it measure???
    Pardon if this question has been asked before but......In regards to a road handlebar, what does the "reach" measurement make reference to? Does anyone know where I can see a picture or illustration of this measurement? Thanks in advance for any feedback.
    Reputation: eltourista84's Avatar
    Apr 2006
    wim
    wim is offline
    Feb 2005
    When talking about a rider's position on the bike, reach generally refers to the distance between the saddle nose and the handlebar.
    When talking about handlebars alone, it's the dimension shown in the drawing.
    several methods...
    Quote Originally Posted by wim
    Your drawing seems to show a center to outside dimension, which is not the most common. The most common for bars in the 70-90mm reach range is center to center. A few measure outside to ouside which adds about 25mm to this value.
    The oddball method, used by Syntace, is the center to outside.
    The picture I've attached shows an outside to outside measurement for Deda, but most online catalogs list the c-c reach.
    Hey C-40.....does the dimension E have a name? I have an anatomic style handlebar on my road bike. When I go down into the drops, I feel like I can't get a good grip on the bars because of the short horizontal piece at the end. My palms drop off the end of the bars. Maybe I'm too stretched out and just need a shorter stem to bring the handlebar a little closer to me so I can get a better grip when in the drops. Or maybe I should switch to the deep style handlebar which seems to have a larger E dimension. Any suggestions or recommendations???
    Man, I'm Awesome
    Reputation: brianmcg's Avatar
    Oct 2002
    Some people call 'E' the "Return". But I don't know if that is set in stone. Sounds good to me though.
    "I like to ride my bicycle." - Lance Armstrong -
    means little...
    The E dimension really doesn't tell you much about the length of straight bar past the curve. Personally, I never used the area near the end. Old style round bars have a useful length at the end, while most anatomics don't. I've even sawed off 2-3cm from some bars.
    When I ride in the hooks I want to be close the brakes and shift levers, so my hands are up just under the lower edge of the brake hood. I've never found the ends useful.
    Jun 2009
    C-40, resurrecting the thread... I have found the ends to be very useful for me when riding in the drops on a casual ride, i.e. when not in a group and when it's not critical to have immediate access to the brake levers. I just bought a set of 3T Ergonovas which do not have any extra length that sticks out behind the tops and I am not going to be able to enjoy them. I need to go with the 3T Ergosum or go back to the FSA Wing Pro Compact, both of which have some extra room to rest on when down deep in the drops. I tend to like this setup.
    Anything is possible when your man smells like Old Spice and not a lady!
    Look 566
    SRAM Rival compact with 12-27
    Dura Ace 7850 SL Tubeless
    Hutchinson Fusion 3
    Cobb V-Flow Plus Saddle
    Aug 2006
    If the reach dimension when measuring a handlebar is defined by the distance between the tops and the spot at which the brake hoods attach, wouldn't that correspond to the overall reach of the bike (saddle to brake hoods)? Meaning, a shorter reach bar equals a shorter saddle to hoods reach.
    Reputation: krisdrum's Avatar
    Oct 2007
    Quote Originally Posted by reebius View Post
    Reach for a frame is usually defined as saddle tip to center of bar at stem intersection, not hoods. So, no, not directly. Granted most of us spend more time on the hoods than on the tops, so there is wiggle room. I think the reason they do not use the hoods is because they are a "movable" object that can be positioned in various ways to accommodate personal preference. The tops are pretty much a constant unless you switch stem lengths.
