Results 1 to 6 of 6
    Reputation: mtrac's Avatar
    Sep 2013
    Help installing Cycliq Fly12
    I have a BDop combination Garmin/GoPro mount. There is not enough clearance to mount a Fly12 so I tried using valve nuts as spacers. After pondering the setup it looks like a accident waiting to happen, so I figured I'd ask what is the best way to install the Fly12? The mount is paid for so I'd like to use it if possible. Thanks.
    Reputation: OldZaskar's Avatar
    Jul 2009
    Why is the mount rotated up so far?
    Edit: I think I get it now... the mount is not adjustable - it's determined by the stem/bar bolts. Not a very versatile mount. Probably going to be easier to go with another mount.
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    You could search for a GoPro mount accessory that lets you drop the camera down lower. They make all kinds of adapters and extensions but Iím not sure that thereís one that just would extend the attach point lower. You might have to Macgyver something.
    I feel your pain. I experimented with a lot of combos to allow me to easily mount a Garmin Virb and now a Fly 12 between several different bikes. I ended up going with over a dozen of these - just in case anyone else is curious. They work very well, took about a week to ship from China.
    https://www.ebay.com/itm/Camera-Moun...53.m1438.l2649
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Wonder if those old-school cupped V-brake washers would help get the angle down a little? But even if so, I'm with you on accident waiting too happen, would much prefer some type of band clamp like hfc posted and keeping the stem bolts clear so they can be torqued properly.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Reputation: faulker479's Avatar
    Jan 2015
    Sep 2013
    I contacted BDop. They said that longer bolts torqued to the correct spec should work, so I'm going to try that first.
  1. Problems with new Cycliq Fly12 CE?
    By OldChipper in forum General Cycling Discussion
    Last Post: 08-03-2018, 10:02 PM
  2. Best deal on Fly12 camera?
    By lostPixels in forum Hot Deals
    Last Post: 08-13-2017, 07:08 PM
  3. So the Fly12 is available now?
    By Christine in forum Commuting, Touring and Ride Reports
    Last Post: 06-18-2016, 04:46 PM
  4. Replies: 16
    Last Post: 07-22-2015, 07:33 AM
  5. Beware - Cycliq Fly 6 HD cam mounts breaking
    By BCSaltchucker in forum Commuting, Touring and Ride Reports
    Last Post: 02-01-2015, 07:34 AM
