Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
  1. #26
    Reputation: Lombard's Avatar
    May 2014
    So they are serving no purpose?
    I have to say while I agree with most of your posts, Kerry, I don't agree with you here. They serve plenty of purpose as if the pressure is low enough, the collars keep the valve from sinking into the tire when putting the pump chuck on. If my bike is going to be inside my car for any length of time on a hot day, I will let some air out. The collars also make it easier for that initial pump up after changing a tube.
  2. #27
    Reputation: velodog's Avatar
    Sep 2007
    I just press the tire to the rim at the valve with the thumb of the hand holding the wheel and press the chuck onto the valve with the other. Never had an issue.
    Too old to ride plastic
  3. #28
    Feb 2002
    Me too.
  4. #29
    Reputation: Oxtox's Avatar
    Aug 2006
    'valve nuts' are totally worthless.
    always discard them and the silly little plastic caps that come with the tube.
  5. #30
    'brifter' is a lame word.
    Quote Originally Posted by Oxtox View Post
    ^This^ It's just something that rattles loose and you constantly re-tighten it til it pulls the valve out of the tube.
    I work for some bike racers
    and a bunch of skateboards
  6. #31
    May 2014
    Maybe it's just because I'm older and my hearing isn't what it used to be, but I have yet to be able to hear a rattling valve collar while I'm riding, much less be annoyed by it.
    Pull the valve out of the tube? Man, you must really be tightening the life out of that thing.
  7. #32
    I see it all the time...people tighten the **** outta those stupid things.
  8. #33
    May 2014
    Yikes! That's pretty dumb. I just tighten it until it touches the rim and stop there. As the tire loses air, it will become tighter anyway.
  9. #34
    Don't buy them to begin with is a better solution.
    If tube makers were smart enough to just not thread the valve all the way to where it touches the pump head then everyone could be happy with the same tubes but until then I wouldn't even think of buying threaded valves.
  10. #35
    Aug 2006
    [QUOTE=Jay Strongbow;5233416]Don't buy them to begin with is a better solution. /QUOTE]
    I switched to smooth stems a long time ago.
    just bought a 6-pack on ebay and the seller shipped me threaded ones by mistake...only reason I'm dealing with nuts again.
  11. #36
    You think it'll tighten itself rather than getting looser? Not likely.
  12. #37
    May 2014
    Really? Try pumping a tire up to 50 PSI, screw the collar down just until it touches the rim. Then inflate the tire up to 100 PSI and see where the collar is sitting.
  13. #38
    Nov 2002
    I think that's a myth. You can't pull the valve stem out of the tube by finger tightening the nut. To prove that, put a tube in and tighten the nut down, then inflate the tire. The nut will be loose. Defective tubes and excessive wiggling of the valve stem while pumping causes the valve stem joint to fail on the tube. Pumps with hoses or using proper technique helps this situation.
  14. #39
    Dec 2005
    Are you saying that the nut will tighten up if you lose pressure and also if it increases pressure?
    I agree with Oxtox, nuts and caps are useless. Once many moons ago I had a flat out on a ride and I could barely loosen the fricker-fracker nut by hand. I swore them off from that point on.
  15. #40
    a real member's member
    Jul 2016
    'valve nuts' are totally worthless. I always discard them and the silly little plastic caps that come with the tube.
    not me. i've been keeping all mine to make a unique sculpture of some sort. it's gonna be huge!
  16. #41
    May 2014
    Quote Originally Posted by ogre View Post
    Oy! The nut will LOOSEN as you increase pressure and TIGHTEN as pressure decreases. I presume that is because as you increase pressure, that presses the tube and valve further up to the valve hole. Did you try what I said above?
  17. #42
    Russian Troll Farmer
    Sep 2016
    Umm...sometimes when I would really hammer up really steep hills, my rear tire would slip on the bead, and my valve stem would end up very crooked. On THAT bike, I'd always put the nuts on.
    "L'enfer, c'est les autres"
  18. #43
    Oh please...
  19. #44
    Apr 2011
    Those with abundant horsepower, bead lock is a must.
  20. #45
    Apr 2011
    Oh please...
    No, that's why some people go with tubeless tire. It's independent of tire slippage.
  21. #46
    Oct 2013
    Slippage anywhere will cause loss of acceleration, that is why I run slicks, 25mm!
    BANNED
  1. Tubes, Tubes, Tubes, there is a difference
    By Mr645 in forum Wheels and Tires
    Last Post: 10-06-2014, 08:26 PM
  2. Replies: 23
    Last Post: 05-31-2014, 07:57 PM
  3. Are all tubes created equal? (Long Valve Tubes)
    By r_mutt in forum Wheels and Tires
    Last Post: 01-30-2008, 06:15 PM
  4. Of tubes more tubes
    By Enviro Mental in forum General Cycling Discussion
    Last Post: 07-08-2005, 10:15 AM
  5. Need Help Picking Race Category for first Crit
    By Dctrofspin in forum Racing, Training, Nutrition, Triathlons
    Last Post: 05-04-2004, 10:07 AM
