Results 1 to 3 of 3
    Witty custom user title
    Reputation: E 12's Avatar
    Jul 2008
    Help with Rotor and/or SRAM crankset conversion
    I have a CAAD 12 which has the BB30a bottom bracket. I'm looking at a couple of different cranksets as an upgrade but having a heck of a time finding install info to meet the BB30a standard. I found a Rotor 3d+ for sale, but the guy has it listed as a new take off from a BBRight frame (Cervelo, of course). Does anyone know what spacer combo I'd need to make this work? Is there somewhere I can buy these spacers without having to attempt to get them direct from Rotor?
    I'm also looking at a SRAM Red BB30 crank - again, what spacer config would I need to work with BB30a? Any help would be greatly appreciated!
    Jul 2013
    I don't know much about BB30a except that it gives way to even more confusion like you are experiencing.
    But, I do know about the Rotor 3D+ you are inquiring about. The "BBright" version is what comes stock on Cervelo crankts and has a 11.5mm space built into the drive side (can't be removed without a special tool and you'd need a new lockring). With it setup like that you can run a normal BBright without any spacers. To get it to work on a PF30 that has a shell width of 68mm then you'd need to get one 11.5mm (or was it 11mm?) spacer for the non-drive side to work.
    For BB30a not sure what combo will work since I don't know enough about it.
    I've run an Rotor 3DF/3D+ (both BBright versions) on my SS EVO with the NDS spacer I mentioned earlier. Don't know where to buy those Rotor spacers beside directly from them though (had to so so myself a while back myself too).
    Jan 2010
    Both are asymmetrical, but different variations on the BB30 idea.
    BBright offsets the shell 11 mm to the NDS. The shell is thus 68 + 11 = 79 mm wide.
    BB30a offsets the NDS by 5 mm. The shell is thus 68 + 5 = 73 mm wide.
    Therefore a BBright specific crank used on a BB30a frame would use the same spacers (if any), on the DS, but would need an additional 6 mm spacer on the NDS.
    This is the theory anyway. In practice there could be a little variance.
    There's sometimes a buggy.
  1. Rotor 3D+ Aero 110 BCD 52-36 170 mm Crankset
    By attwyn in forum Components, Wrenching
    Last Post: 04-10-2015, 04:21 AM
  2. rotor vs sram crankset
    By shotojs78 in forum Cervelo
    Last Post: 12-15-2013, 03:20 AM
  3. Rotor crankset- non Q rings
    By Lookbiker in forum Components, Wrenching
    Last Post: 12-12-2011, 08:22 PM
  4. Rotor 3D vs FSA SLK Light crankset
    By djdube525 in forum Components, Wrenching
    Last Post: 06-19-2011, 05:20 PM
  5. Which crankset should I go with? Rotor 3d, FSA SL-K, and SRAM
    By petalpower in forum General Cycling Discussion
    Last Post: 05-11-2010, 07:59 AM
VISIT US AT and the ConsumerReview Network are business units of Invenda Corporation
