Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Reputation: walrus's Avatar
    How?
    I had plenty of chain with the Shimano 105 chain that came in the group, even took 3 links out. You can see in the picture it's in the 40, I don't remember if it was in the 34 or the 50. I rode it 51 miles today with no problem, never had to use the 40..B screw in backwards.
  2. #27
    'brifter' is a lame word.
    Quote Originally Posted by walrus View Post
    You might have misunderstood what I was talking about. Do you somehow have enough chain so that you can go big/big and be ok?
    I work for some bike racers
    and a bunch of skateboards
  3. #28
    Reputation: Lombard's Avatar
    May 2014
    There appears to be a misunderstanding among many that the geometry of the derailleur is the only limiting factor. If that were the case, Walrus' remedy would work.
    But the fact that we are dealing with such a range between the largest and smallest cogs means we need to pick up more chain length difference than with a smaller range cassette. This requires a longer cage, no exceptions unless you want the chain to go slack in small-small or want the chain to bind in large-large.
    It's not hard. Just like the fact that you can't fit 10lbs. of s#!t in a 1lb. bag.
  4. #29
    Out riding.
    Reputation: 1500SLR's Avatar
    Sep 2018
    The 10lbs of poop in a one pound bag is a good analogy.
  5. #30
    Like I said it went into the 50-40 easily even after I took out two links, I took 1 more link because I had serious slack in the 34-11. It still would go into the 34-50 on the stand without the 3 links, but not easily. I'll never try the 34-40 on the road, or the 34-11. I rode it 51 miles yesterday and never needed or wanted to go into the 34-50. Everything shifted very smoothly.
  6. #31
    Feb 2010
    Yeah, I wouldn't consider that working if I didn't have access to all of my gears. Plus you're risking pretty severe damage to your bike and a crash if things go poorly. Hard pass. Good for you if it works for you, but I hope you never find yourself deep in the red big-ringing a climb and shift one too many times when your heart rate is pegged and you're not thinking "wait, I can't shift all the way to the big cog, I'd better be careful."
  7. #32
    Out riding.
    Sep 2018
    If you'll never try it on the road I don't understand the point of having it. If you really want a lower gear and you have some sort of issue about a medium cage derailleur then get a compact crank.
  8. #33
    As I expected your set up isn't correct. There is no way you can get all gear combinations w/ your derailleur.
  9. #34
    Banned forever.....or not
    Aug 2002
    If you have a Shimano rear wheel, you'll need a new one with 11 speed.
    Dogbert.
    I>U
  10. #35
    Out riding.
    Sep 2018
    Yeah if you're going to go up to 11speed a new wheel and hub would be nescessary.
  1. Upgrade, upgrade, upgrade... but when to consider the frame and fork?
    By OldZaskar in forum Bikes, Frames and Forks
    Last Post: 08-14-2014, 06:37 PM
  2. To upgrade or not to upgrade...help!
    By jamesmoody in forum Bikes, Frames and Forks
    Last Post: 07-22-2012, 11:24 AM
  3. upgrade or upgrade?
    By Radio63 in forum Bikes, Frames and Forks
    Last Post: 06-22-2009, 09:43 AM
  4. Wheel upgrade or Bikes Direct/Frame upgrade
    By flat ark in forum Bikes, Frames and Forks
    Last Post: 04-07-2007, 12:05 PM
  5. To Upgrade or Not to Upgrade
    By EE33 in forum General Cycling Discussion
    Last Post: 08-30-2005, 05:03 PM
