Results 1 to 3 of 3
    JML
    JML is offline
    Reputation: JML's Avatar
    May 2003
    Hex Key comparison
    I have a large collection of hex heys from various manufacturers, and just spent some time figuring out which had the best fit for my bike toolbox/seatpack. I looked at Wera (Germany), Wiha (Germany), Gearwrench (Taiwan), HexPro (folding keys from Taiwan), Bondus (several variants), Park (all of their hex keys, regardless of style, are sourced from Bondus), Pedros, Craftsman (old US-made tools), Allen (also old US-made), and some multitools from Park and CrankBrothers. All of these have chamfered ends, by the way. (I would like to have tried the PBTools keys from Switzerland, but don't have any.)
    And no, I don't "collect" these things! But I have different toolsets for my car, home, electrical work, various hobbies, etc., and don't like going to one master cabinet, toolbox, or toolbag for a project.
    For separate keys (regular tip or ball-tip), the least play (i.e., the tightest fit) is found with the Bondhus Briteguard or Goldguard line. Those are plated versions (chrome or gold, respectively) of keys made of their Protanium steel. The plating must add just enough to the underlying metal to make for a closer fit than the unplated black-finished Bondhus keys. They just wobble less. There's no problem fitting them into any recess, but they are less likely to damage fasteners or cam-out. They come in short versions, long versions, and long versions with ball-ends. All are made in the US, and they're inexpensive.
    For 3/8"-drive ratchet sets, using sockets with inserts, old US-made Craftsman are excellent (I think these used to be made by S-K for Sears, but I got them decades ago before everything became sourced from China and became junk).
    For current production 1/4"-drive sockets with hex inserts, the Gearwrench sockets are excellent and inexpensive.
    If you want 1/4" insert bits, the Wiha bits are the best I could find. (Several of these and a Prestaratchet make for a good addition to the seat bag.) And if you need flat-tip insert bits, the Wiha and Wera lines have hollow-ground tips that won't damage slotted screw heads.
    The worst fits? The multi-tools.
    1984 3Rensho SR Export Road & Campy NR/SR Grouppo
    Reputation: looigi's Avatar
    Nov 2010
    Thanks for the tip. I have a coupla sets of Bondhus L wrenches that are kinda worn and was looking to get a new set so will check out the Briteguard. One thing I do on non-ball end wrenches is cut off the 3-6mm that are worn with a cutoff wheel, making sure to keep the wrench cool so as not to affect its hardness. This also produces a nice flat end with no significant chamfer (after careful deburring).
    ... 'cuz that's how I roll.
    So. Calif.
    Reputation: tom_h's Avatar
    May 2008
    Bondhus is my favorite, too. Park Tool uses the Bondhus wrenches assembled inside most of their Park products (eg, the "Y" wrenches).
    Multitool hex keys are both too soft and too loose fitting -- has to be a real emergency before I use one of those.
    I wish more bike fasteners were Torx, those rarely cam-out or strip.
    But, Torx is a patented design and with the license fees piled on, the fastener cost is apparently too much for most component & bike manufacturers.
    Campy uses a few Torx on their stuff.
    JML
    JML is offline
    May 2003
    I decided to get a set of PB Swiss keys, too. These are absolutely the finest I've ever seen. The fit is great and the finish is unparalleled (but so is the price).
  1. Wattage Comparison
    By jwgd in forum Racing, Training, Nutrition, Triathlons
    Last Post: 09-16-2009, 05:37 AM
  2. components comparison
    By vontress in forum Components, Wrenching
    Last Post: 07-19-2009, 08:31 PM
  3. Price comparison LBS vs PBK
    By JoWu in forum Hot Deals
    Last Post: 05-14-2009, 10:54 AM
  4. Tire Comparison
    By Mr. Jones in forum General Cycling Discussion
    Last Post: 05-21-2007, 04:06 PM
  5. Fair Comparison - F4:13
    By fea in forum Pinarello
    Last Post: 02-04-2006, 03:26 PM
