Results 1 to 10 of 10
    a real member's member
    Jul 2016
    how do you true chainrings?
    for slightly bent chainrings, what do you do? take it off the arm first? leave it on? use vise-grips (and maybe a rag on the ring to protect damage)? use a special tool? live with it? ever made the slight problem worse?
    Dec 2006
    I have a special tool-can't remember what brand it is or where I got it.
    It's rectangular steel stock about 9" long and 1"+tall. A slot is cut into the 1" tall section near each end; they vary in width to accommodate different chainring widths (think of a thick ruler). Usually you slip it onto the chainring spider arms while the ring is mounted to the crank, to bend the chainring into plane.
    I've never made the problem worse; just kept tweaking until it was straight enough.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    'brifter' is a lame word.
    If it's a flat aluminum ring then do what rideit says above. If it's a Shimano hollow ring buy a new one.
    I work for some bike racers
    and a bunch of skateboards
    Russian Troll Farmer
    Sep 2016
    I generally take it off the bike, put it in the vise at work (protected by a rag), and start tweaking it with a bar (I have a super-heavy-duty screwdriver that works well), then I take it over to the plate, and measure runout with an indicator. I can get them to within .001" if I have the time. Having a full machine shop at my disposal is a help, though..
    "L'enfer, c'est les autres"
    Feb 2005
    Good point!
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by rideit View Post
    This.
    Too old to ride plastic
    Feb 2002
    Use a bigger wrench to get more of the ring between the jaws. The picture is of an 8" - I prefer 12". And note that with aluminum cranks, it is often one of the spider arms that is tweaked rather than the ring.
    Jul 2016
    thanks, all.
    Feb 2005
    Yeah, I just used the first image that popped up. 12" is better (heheh...that's what she said)
  1. Wheels: How true is true enough?
    By dinga in forum Wheels and Tires
    Last Post: 05-13-2016, 11:02 AM
  2. How to true chainrings ?
    By Ab24029 in forum Components, Wrenching
    Last Post: 03-11-2006, 05:27 PM
  3. Calling all deep carbon rim owners: How true is true?
    By BikinBrian in forum Components, Wrenching
    Last Post: 11-01-2004, 11:41 AM
  4. Calling all deep carbon rim owners: How true is true?
    By BikinBrian in forum General Cycling Discussion
    Last Post: 11-01-2004, 06:08 AM
  5. Calling all deep carbon rim owners: How true is true?
    Last Post: 10-30-2004, 08:38 PM
