Results 1 to 13 of 13
    Jan 2009
    How drill hole in shoe sole?
    I want to make a ventilation hole in the sole, like whats on some shoes.
    What tools do I use? Drill?
    eRacer
    Reputation: jmlapoint's Avatar
    Sep 2008
    I am not sure that is a good idea.
    Most cycling shoes breathe pretty well through the top, and drilling holes in the sole is not going to increase ventilation due to insole, and may weaken the sole.
    Just my opinion.
    John
    John Lapoint / San Diego
    God is Great, Beer is Good, and People are Crazy!
    Banned forever.....or not
    Aug 2002
    It will work if you start with a small drill and move up with larger sizes.
    Won't make much difference, though. Even if you have a 1/4 inch hole, how much air can get in there??
    Dogbert.
    I>U
    Jan 2009
    shoe sole hole
    Quote Originally Posted by jmlapoint
    Just my opinion.
    John
    Can I use an attachment with dremel? Or something else?
    Low Idiot Tolerance
    When I want to drill a hole I use a drill.
    I used to use an angle grinder, then I tried a welder and finally gave a food processor a run. In the long run I found that if I wanted to drill a hole, then a drill was the best option.
    As for drilling your shoes, I think you have more to lose than gain, but if your heart is set on it, then weld away. I mean, drill away.
    Grumps
    Reputation: blakcloud's Avatar
    Apr 2006
    A Dremel will work fine. I use my Dremel to drill all the time, just put a bit in there and drill away.
    Aug 2009
    You might get better results by wearing better socks.
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    @framesti,
    what you need is the Park Tool Sole-Holer, part number APR0110. It's a tool specially made from trilithium steel to take care of this task. Just be sure to lubricate the tool with pure whale oil or it will overheat and you'll torch the tool's warranty.
    "Luminous beings are we...not this crude matter!"
    Reputation: Infini's Avatar
    Apr 2003
    How many holes are you going to make?.. You do realize that on top of the carbon sole is the insole, and then your foot... Either one of these will prevent air from moving through the hole I guess if you drill through both the sole and insole, the air would be touching your sock, unless you cut corresponding wholes in your socks! Now we're talking.
    Only benefit of drilling holes would be weight reduction.. About 2 grams, at the expense of a slightly higher coefficient of drag, unless you already always wear shoe overs, in which case, just take those off and you will have more circulation..
    If you really want better air circulation, drill holes in the top or sides of the shoe... Or just buy shoes with uppers that breath better..
    Feb 2002
    Actual benefit
    Quote Originally Posted by Infini
    Nope. The benefit is that when you ride in a drenching rain, your shoes will drain instead of filling up with water. That's it. No cooling advantage, and like you said, no weight savings to speak of.
    Apr 2003
    Quote Originally Posted by Kerry Irons
    ohh, I hadn't even thought of that one... you're right, that would be the greatest benefit.
    Jan 2009
    drill hole in sole tool?
    Quote Originally Posted by Uncle Grumpy
    Grumps
    Do you have a link to what youre recommending? Do you mean like electric screwdriver? I guess I need carbide material?
    Low Idiot Tolerance
    Quote Originally Posted by framesti
    Yes. Use an electric screwdriver.
    But not carbide, for something as intense as the nylon or carbon composite used in the typical bicycle shoe sole, you're going to need a platiunum-iridium drill bit.
    I have to go now. My planet needs me.
    Grumps
