Results 1 to 10 of 10
    Aug 2009
    How to install bar end shifters on a drop bar?
    See question in title.
    As I don't seem to be able to find any 9 speed downtube shifters on the local market, I think I will have to use 9-speed bar end shifters, which are available.
    How do you install them on a drop bar? I had a brief conversation with my mecanic and he pretended the cable has to be routed through the drop bar, in which a pair of holes would have to be made to allow them to "escape".
    Is it possible to guide the cable on the outside of the drop bar or does this type of mechanism require it goes through the inside?
    Nov 2006
    You could use these if you like ten speed.
    http://edinabike.com/page.cfm?pageid...d=15593&type=T
    And I'm pretty sure these come with a conversion to be used on a downtube, at least my Ultegra 10's did.
    http://edinabike.com/page.cfm?pageid...ils&sku=LD0704
    To answer your question, your mechanic is an wrong. Bar end shifters are mounted outside the bar, under the tape. I'm looking at my TT setup right now.
    hello
    Reputation: roadfix's Avatar
    Jun 2006
    Your mechanic obviously has no experience with traditional bar end shifters. The shifter cables run underneath the bar tape and traditionally exits at the lower bends.
    Or you can go ergo and run the cables all the way to the top and have them exit at the stem. That's how I run my cables for a cleaner look.
    SurlySteamrollerLitespeedClassicBianchiPista
    DeanColonelSurlyLongHaulTruckerKonaKu
    LitespeedFirenzeCinelliOlympic
    Aug 2009
    Quote Originally Posted by kbiker3111
    Thanks for the info. And yes, I have been googling how to install bar end shifters and my mecanic was indeed wrong. The cables go on the outside. Only the plug goes on the inside.
    I have tracked down a pair of Dura Ace bar end shifters in another shop and yes, they come with a conversion kit for downtube, which has the advantage that you can adjust the cable tension if the derailleur is slightly off.
    I need 9-speed shifters for my derailleur, that is why I will have to opt for the bar end shifters. I was able to find 10-speed downtube shifters on the local market, but I would not be able to use them in index mode with my 9-speed derailleur.
    Aug 2009
    Quote Originally Posted by roadfix
    Yep, obviously he has never installed any. By googling a little I found the correct installation procedure.
    BTW, I think your idea for running the cables to the top is indeed a cleaner looking way.
    Low Idiot Tolerance
    Just mount the bar end shifters to the downtube.
    Why not just change to 10speed if you can get 10sp downtube shifters? I mean, I hardly consider 10sp to be an upgrade, but sometimes the lack of suitable 9sp stuff necessitates a change.
    Damn you obsolescence!!!
    Grumps
    ARP
    ARP is offline
    Mar 2002
    Here are a few pics of the cleaner setup
    DA tens cable housing out the top near the stem. I have seen online Ultegra 9 speed bar ends and DT shifters that index the rear and friction the front. No links though, ebay I believe.
    Attached Thumbnails Attached Thumbnails How to install bar end shifters on a drop bar?-decals-011.jpg
    Aug 2009
    Quote Originally Posted by ARP
    Thanks for the pics. That looks indeed like a very clean job.
    I will have to opt for bar end shifters because I cannot find 9 speed DT shifters on the local market (I live in Ecuador) and purchasing them through ebay and having them shipped over here is just too much of a hassle. It has to be 9 speed for the derailleur. I would have preferred DT shifters, if I had the choice though. But OTOH the bar end shifters come with a whole cable set and with the adaptors to be able to tense the cable on the downtube, so that is not a bad thing either.
    Roadie with unshaven legs
    Dec 2005
    I've installed a pair of bar-end shifters on one bike where I drilled a few holes into the handlebar to route the cables internally. Works great for me.
    You can see that the hump disappears after about an inch under the bar tape in this picture.
    This is where they come out. Note that this handlebar has carbon fiber reinforcing the center section and it is only because of this that I felt safe drilling a hole for the cable routing. It is an aluminum handlebar with a cosmetic carbon fiber center section.
    Aug 2009
    Nice pics and an original setup. I would hesitate to do this to my Cinelli handlebar though. As you say, yours is reinforced so drilling holes can be done.
